Old 02-04-2013, 01:59 PM
HostMary HostMary is offline
Default MBox Mini and Headphones Mystery
Hi -
I use an MBox Mini and I had to move so it was disassembled, now I can only hear out of the left side. I've tried another headphone but it's the same issue so I'm guessing I don't have it plugged in correctly to the MBox?
Any thoughts? Could it be a setting in ProTools?
Thank you for your help,
Mary
Old 02-04-2013, 05:13 PM
Default Re: MBox Mini and Headphones Mystery
Okay, I re-read my post and it was not very clear...I have a an MBox Mini that I use along with ProTools to do voice overs. When I moved my equipment something happened to the settings for the headphones because I can only hear audio in the left headphone. My mic is fine just the headphones. I keep trying different configurations of the headphones cord into the MBox but to no avail. I plugged a different headphone in - same problem.
I'm wondering if there is a control for the headphones in the ProTools software?
Any troubleshooting would be helpful (and hopeful).
Thank you!
Mary
Old 02-04-2013, 05:40 PM
sunburst79 sunburst79 is offline
You might try setting you outputs to default in the I/O section of the preferences. It could be as something as simple as a pan pot panned all the way over. Is this one session or all sessions? You have any hidden tracks?
Scott
Formerly Hobo Wan Kenobi
Core 2 Specs Page
ASUS P6T6 Revolution | i7 930 | 12GB OCZ DDR3 1600 7-7-7-20 | PTLE 10 | CPTK | 003 | Presonus D8 | 11Rack | Alesis AI3 | Presonus HP60 | Mercury + Studio Classics | Sound Toys | MasseyPack | Axiom61 | MAudio Keystation Pro 88
Old 02-05-2013, 09:50 AM
Are you possibly recording a mono signal to a stereo track?(that's a common mistake for newbies)
Old 02-08-2013, 01:37 PM
Thanks Sunburst and Albee (who are you calling a newbee? )
Okay, I know I don't utilize all that ProTools has to offer. I just record, edit, burn to disc. I'm sure there is a solution in what both of you have suggested but my ProTools language is limited, ugh.
Its every session and I have the headphones plugged into the Midi in "mon out".
Now my waveform is really small...
Any help is greatly appreciated.
Mary
Old 02-12-2013, 05:30 AM
Mary
The monitor outputs on the back of the unit are single channel - only left or right. They're NOT for connecting to headphones - they don't have the power necessary to drive headphones anyways. . Why don't you use the headphone jack on the front panel? And there's a volume control on the front panel for that level.
Jack
QAPLA!
Old 02-12-2013, 09:20 AM
There is this....you should be using the headphone jack.
Scott
Core 2 Specs Page
Mbox 2 Mini Sound coming through both Monitors and headphones jt1432 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 1 03-12-2011 11:06 PM
Possible to listen through MBOX 2 mini with headphones? (e.g. winamp & youtube) kbbajer 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 9 03-26-2010 03:48 PM
Alt output for headphones on an MBox Mini Ziko 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 2 07-28-2008 05:44 PM
mbox mystery RShindell 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 12 02-01-2005 06:16 PM
Help me out of this mystery MBox\LE6.1 SilkyRay 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 2 05-10-2004 09:58 PM
