Old 02-09-2010, 11:28 AM
xRollinx xRollinx is offline
Exclamation Update only works on Installation...cannot perform installation on Win7
As the title says, I've just got the Pro Tools 8 M-Powered and installation won't even begin. Clicking on install pro tools from the splash menu on the cd opens a new window that says "Setup.exe has stopped working." I know the 8.0.3 update will allow me to use Pro Tools on win7 but it is an UPDATE and I cannot update something that isn't installed.
What can I do to get this thing installed and updated to the win7 compatible version?
Old 02-09-2010, 12:00 PM
scenicrecords scenicrecords is offline
Default Re: Update only works on Installation...cannot perform installation on Win7
I was able to install the Full Installer of 8.0 on Win 7 then update to 8.0.3. Re-download the 8.0 Installer and try it again. It may be corrupted.
Old 02-09-2010, 12:05 PM
Where can I find the full installer for 8.0? I purchased a physical CD
Old 02-10-2010, 08:10 AM
I bought the Digital Download from Sweetwater. You can probably register your PT on Digidesign's website, login, go to my products, and download from there.
Old 02-10-2010, 05:08 PM
necjamc necjamc is offline
If you register through MyDigi, you can download 8.0 through your account.
I was also able to install 8.0 on win 7 64bit
Try copying the dvd to your hard drive and running the setup there. It's faster to install and less problems with the dvd errors.
Edit: I don't know if when you by the physical disk, if MyDigi has the full installers, but you should def try to copy the dvd over to you hd.
Old 02-12-2010, 07:35 PM
TOM@METRO's Avatar
If you have PT8 registered with Digi, contact them and arrange to have the full installer for 8.0.3 placed in you account, this is a far simpler way to install.
~ tom thomas
Formerly hobotom
HD Omni and 192 I/Os
Windows 10
Intel Hexcore i7
All Samsung Pro SSDs
Ampex MM1200 2" 24 trk tape
www.metrostudios.com
Pro Tools 8 LE on Win7 Installation Help Needed BrendanB 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 1 01-06-2012 07:42 PM
Can I have both a PT LE 8 and PT 9 install on the same Win7 installation? Skwaidu 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 2 12-08-2010 12:33 PM
Upgraded to Win7, new PT installation can't see HW leftbrain99 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 3 12-06-2010 10:47 PM
LE 8.0.4 Installation Failures on Win7 + Solution finches 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 3 08-10-2010 03:30 PM
Installation problems - win7 danny1990 Pro Tools SE and Essential (Win) 0 08-07-2010 11:37 AM
