Old 10-26-2009, 07:45 AM
KGB2011 KGB2011 is offline
Default Set up PT for 3/4 5/4 6/8 ... time signatures
Hy. If i want to do a 5/4 time signature how do i setup PT ?
Thanks !
Old 10-26-2009, 09:28 AM
barstool719 barstool719 is offline
Default Re: Set up PT for 3/4 5/4 6/8 ... time signatures
click view > rulers > meter
select the bar/beat where you want your meter change, click the plus sign on the meter ruler, input your time sig, and viola
if you have multiple meter changes, just add them as needed
i7-860 / 12GB Kingston / Intel DP55WB / 500GB Barracuda / 1TB Deskstar W7x64
Focusrite Saffire Pro 40 / Pro Tools 9.0.3
Mics, Guitars, Amps, Basses, Drums, Keys
http://overtheeffect.bandcamp.com
Old 10-26-2009, 12:20 PM
Thanks !
Old 10-11-2010, 07:33 PM
synchaotica synchaotica is offline
I have tried this on one of my tracks and every time I click in the box to type '3' (to change tempo to 3/4 time) it defaults back to '1' and wont let me type anything in after that, it comes up with a dialog box saying "this field requires values in the range of 1 and 99' After I click 'ok' it reverts straight back to 4/4 time. I'm a bit confused as to why this seems to be locked at 4/4 time. (in the meter bar it says Default: 4/4) Most likely something I haven't seen. Can you please help me with this?
Old 10-11-2010, 07:38 PM
Never mind... seems to be working now... have no idea what happened there...
Using BOOM with Odd Time Signatures (3/4....6/8) NYKeys Virtual Instruments 9 07-25-2023 02:00 PM
Strike 1.5 Odd Time Signatures Amin7b5 Virtual Instruments 1 04-06-2010 08:02 AM
Crazy time signatures... SFR General Discussion 1 01-25-2010 01:24 PM
two different time signatures in one session? elv1s1sal1ve 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 3 08-28-2006 07:36 PM
Pro Tools and Odd Time signatures RhythmMaster Pro Tools TDM Systems (Mac) 2 02-03-2006 07:49 AM
