axiom 25 / ProTools - not working!
Hi!
I've never seen anyone with the same problem, my pro tools 7.4cs2 recognizes my Axiom 25, I add a midi track, click record, and I it sees every note that I play on the Axiom, it records the midi, but I can't hear anything! I looked everywhere and tried to change everything, but couldn't figure out what to do. I use a MobilePre USB by M-Audio with Pro Tools, and it works perfectly. What should I do to make the midi that's coming in from the Axiom sound through the MobilePre? |
Re: axiom 25 / ProTools - not working!
The Axiom is only a MIDI controller. It has no capabilities to generate any sound, it just produces the MIDI data that tells a sound module what to play. You need to pick a sound module or virtual instrument plugin to use.
I now it doesn't make any sound... I told the name of the preamp I use in case there was any compability issue. My axiom works fine when I try other softwares (like Sony Acid Studio), but with PT it doesn't. How can I create a virtual instrument?? Thanks.
Which Virtual Instruments do you have installed? Some "other softwares" (like acid studio) work differently. You should not expect Pro Tools to function like them.
Those are the basics. For any more detailed instruction, we would need to know which specific virtual instrument plugin you are trying to use.
hey -- you say that the Axiom 25 works perfect with ACID -- i am having the SAME problem you had BUT with ACID--how do i resolve it..why can i see the notes being played BUT nothing during playback of track?
axiom 61 not working | thecaptainandme | Pro Tools M-Powered (Mac) | 0 | 05-18-2012 04:19 AM |
MMC with Axiom 49 not working | thisistruth | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 2 | 11-19-2010 07:03 AM |
8.04 working well but not with axiom pro | M.I.A.G.T. | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 2 | 07-25-2010 06:39 AM |
Axiom 49 only 1 Key working with midi | aramka | MIDI | 1 | 12-28-2009 07:53 PM |
Axiom 25 not working in PT 8 | cary chilton | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 15 | 03-18-2009 11:07 AM |
