Tracks not muting
I'm trying to fade some guitar tracks I do the fade and mute the tracks but sound keeps comming out.
What am I doing wrong. Thanks Guys |
Re: Tracks not muting
Can anyone help?
Thanks |
Hi JHJ,
dumb question, do have any aux sends aktivated in this track? regards Jochen |
Yes I do and they won't mute either. Am I missing somthing?
Thanks |
you might not be writing your mute automation. are you doing it from your edit window or mix window? I usually do my mute automation in the edit window.
from the edit window: on the guitar track you want to work with, click on "waveform" and change it to "mute" with your selector tool, highlight what you want muted grab your trimmer tool and pull the mute automation line down until it indicates that your selection is muted. HTH
Have a great day..... Bill ---------------------- Mac Mini (2019) 3.2 Ghz - 6 Core i7 Mojave with 64 GB RAM PT Ultimate (2019.10) Motu 16a C/24 Control Surface |
I believe the info is being written. The trac mutes(yello m's) even when I mute manually the sound keeps comming. I can't keep these tracks from playing nor will they fade, faders go down sound stays up?
Help |
Do you have a pre-fader send on the tracks?
How do I tell if they are pre or post fader sends? That must be it
Thanks |
You can choose for each individual send if you want it pre or post fader. Just click on the send, and there you'll see a box named "pre". If it's lit (white), then the send is pre fader. If it's grey, the send is post fader.
Tracks Muting During Bounce | jeoffharris | General Discussion | 6 | 11-13-2013 08:00 AM |
Tracks Muting bug is back in PT HD 10.2.0 | mgoorevich | macOS | 8 | 07-28-2012 08:21 AM |
Solo not muting all tracks | Stickman7 | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 2 | 06-18-2009 07:06 PM |
Muting tracks with no reason | Alécio Costa | Pro Tools TDM Systems (Mac) | 39 | 11-12-2003 07:07 PM |
Muting tracks during bounce | phdumas | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 3 | 12-03-2001 07:51 AM |
