Old 01-31-2005, 03:31 PM
RShindell RShindell is offline
Default mbox mystery
Any help dealing with the following would be greatly appreciated.
After having just installed PTLE 6.1 for Mbox onto my G4 1.33 (512), I can't seem to get PT to read any audio coming from the box. The microphone's level is registering on the Mbox's peak light, but not in the program. Audio input is set correctly, and record is enabled. The USB cable seems to work properly (all lights are on and the spdif and USB lights respond when I switch from the program).
Thanks in advance for providing what will no doubt turn out to be an embarassingly simple solution.
Old 01-31-2005, 05:16 PM
RadioMoo RadioMoo is offline
Default Re: mbox mystery
Launch Pro Tools and select 'Setups.' Go to I/O Setup>Input. You'll see your Mbox represented here; just hit the 'Default' button and click 'OK.'
Then go to Windows>Show Workspace; you'll see a column marked "A" at the top and one marked "V." Make sure that there is an "R" under each of those; if not, click on the letter itself (P or T) and from the drop-down select 'Record.'
That's all I can think of; if these don't work, post back.
Mbox 1 w/BLA mod, PTLE 6.1, eMac 700MHz, OS X (10.2.8), 1024 MB RAM
Old 01-31-2005, 05:47 PM
Still nothing. There were already Rs in the "A"and "V" columns. Thanks for jumping in.
Old 01-31-2005, 06:11 PM
Have you used ProTools before?
You need to enable record on the track, AND in the transport.
Quad 2.5 G5, 4.5G RAM
Old 01-31-2005, 11:20 PM
Yes, record is enabled on both the transport and in the track. By the way, if I hit the play button in the transport, I get a message (-9135) saying that the Mbox is not connected. Cheers.
Old 02-01-2005, 08:43 AM
DigiTechSupt's Avatar
Please try quitting Pro Tools and then unplug and replug the USB cable from the back of the Mbox. If this solves the problem, you may want to try reloading the Mbox firmware as a long term solution. You can find the firmware download here .
regards,
Digidesign Technical Support
Avid Audio Tech Support
Support FAQ
Old 02-01-2005, 09:18 AM
I had already tried that. Perhaps this is not relevant, but in System Preferences>Sound, although the Mbox does show up in list of devices, it's accompanied by a message saying that "the selected device has no input [or output] controls". Another interesting tidbit: if I hit Play in the transport window, Protools crashes and closes. Happens without fail every time. The mystery continues....
Old 02-01-2005, 09:30 AM
What is your version of the Mac OS?
Pro Tools LE 6.1 is incompatible with any version of Mac OS 10.3. If you are running 10.3 (Panther), please download the free update to Pro Tools LE 6.4.
regards,
Support FAQ
Old 02-01-2005, 09:34 AM
Well, well. It seems I'm running 10.3.4. I'll download the update and let you know. Hope springs eternal.
Old 02-01-2005, 12:31 PM
Eureka! Like I said in my first post - embarassingly simple. However, I must also say that it never occured to me that Digidesign would have compatibility problems with any recent version of the Mac OS. I mean, you guys talk to each other on a regular basis, right? Anyway, all's well that ends well. Thank you.
MBox Mini and Headphones Mystery HostMary MIDI 6 02-12-2013 09:20 AM
A new mystery...why? Fastermouse 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 7 04-06-2010 04:45 PM
CD mystery sw rec 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 8 01-22-2007 01:25 PM
Help me out of this mystery MBox\LE6.1 SilkyRay 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 2 05-10-2004 09:58 PM
MBox Bouncing mystery, a solution? Hskala 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 3 02-18-2003 09:20 AM
