PT First Crashes on open
I have reinstalled and restarted several times.
I have also reinstalled the Focusrite software. I am using a Focusrite Scarlett Solo. Here is my Sandra Report: SiSoftware Sandra ID Host Name : Name-pc Workgroup : WORKGROUP Computer Model : ASUS All Series ASUS MB Serial Number : System Ser********** Chassis : Desktop Mainboard : ASUS B85M-E Serial Number : 1309155******** BIOS : AMI (OEM) 0601 08/22/2013 Intel vPro : 9.00.02.1345 Total Memory : 12GB DIMM DDR3 Processors Processor : Intel(R) Core(TM) i7-4770 CPU @ 3.40GHz (4C 8T 3.89GHz, 3.9GHz IMC, 4x 256kB L2, 8MB L3) Socket/Slot : FC LGA1150 Chipset Memory Controller : ASUS Core (Haswell) DRAM Controller 100MHz, 2x 6GB DIMM DDR3 1.33GHz 128-bit Memory Module(s) Memory Module : Crucial BLS8G3D1609DS1S00 8GB DIMM DDR3 PC3-12800U DDR3-1600 (9-9-9-24 4-39-12-6) Memory Module : Corsair CM3X2G1600C8D 2GB DIMM DDR3 PC3-12800U DDR3-1600 (9-9-9-24 5-34-10-5) Memory Module : Corsair CM3X2G1600C8D 2GB DIMM DDR3 PC3-12800U DDR3-1600 (9-9-9-24 5-34-10-5) Video System Monitor/Panel : ACI ASUS VW224 (1680x1050, 22.0") Monitor/Panel : Dell Computer DELL U2410 (1920x1200, 24.0") Video Adapter : NVIDIA GeForce GTX 970 (13CU 1664SP SM5.2 1.16GHz/1.5GHz, 1.8MB L2, 4GB 7GHz 256-bit, PCIe 3.00 x16) Video Adapter : NVIDIA GeForce GTX 970 (13CU 1664SP SM5.2 1.16GHz/1.5GHz, 1.8MB L2, 4GB 6GHz/7GHz 256-bit, PCIe 3.00 x16) Graphics Processor CUDA GP Processor : NVIDIA GeForce GTX 970 (1664SP 13C 1.16GHz/1.5GHz, 1.8MB L2, 4GB 6GHz/7GHz 256-bit) OpenCL GP Processor : NVIDIA GeForce GTX 970 (1664SP 13C 1.16GHz/1.5GHz, 208kB L2, 4GB 6GHz/7GHz 256-bit) Compute Shader Processor : NVIDIA GeForce GTX 970 (1664SP 13C 1.16GHz/1.5GHz, 1.8MB L2, 4GB 6GHz/7GHz 256-bit) OpenGL Processor : GeForce GTX 970/PCIe/SSE2 (4GB) OpenGL Processor : GeForce GTX 970/PCIe/SSE2 (4GB) Storage Devices WDC WD10EZEX-00KUWA0 (1TB, SATA600, 3.5", 7200rpm) : 932GB (E:) Samsung SSD 840 PRO Series (128GB, SATA600, SSD) : 119GB (C:) Samsung SSD 840 EVO 120GB (120GB, SATA600, SSD, OPAL) : 112GB (D:) Seagate ST3320820AS (320.1GB, SATA300, 3.5", 8MB Cache) : 298GB (F:) Samsung SSD 840 Series (120GB, SATA300/600, SSD) : 112GB (G:) SanDisk pSSD (62.7GB, USB3/SATA300/600, 1.8", SSD) : 58GB (H:) Ultra HS-SD/MMC (USB2/NVMe) : N/A (I:) HL-DT-ST DVDRAM GH24NSB0 (SATA150, DVD+-RW, CD-RW) : N/A (A:) Logical Storage Devices MainFiles (E:) : 932GB (NTFS, 4kB) @ WDC WD10EZEX-00KUWA0 (1TB, SATA600, 3.5", 7200rpm) System Reserved : 350MB (NTFS, 4kB) @ Samsung SSD 840 PRO Series (128GB, SATA600, SSD) Apps SSD (D:) : 112GB (NTFS, 4kB) @ Samsung SSD 840 EVO 120GB (120GB, SATA600, SSD, OPAL) Back Up Drive (F:) : 298GB (NTFS, 4kB) @ Seagate ST3320820AS (320.1GB, SATA300, 3.5", 8MB Cache) Steam Games SSD (G:) : 112GB (NTFS, 4kB) @ Samsung SSD 840 Series (120GB, SATA300/600, SSD) Removable Drive (H:) : 58GB (FAT32, 16kB) @ SanDisk pSSD (62.7GB, USB3/SATA300/600, 1.8", SSD) Local Disk SSD (C:) : 119GB (NTFS, 4kB) @ Samsung SSD 840 PRO Series (128GB, SATA600, SSD) Removable Drive (I:) : N/A @ Ultra HS-SD/MMC (USB2/NVMe) Optical Drive (A:) : N/A @ HL-DT-ST DVDRAM GH24NSB0 (SATA150, DVD+-RW, CD-RW) Peripherals LPC Hub Controller 1 : ASUS Lynx Point LPC Controller Audio Device : ASUS Lynx Point HD Audio Controller Audio Codec : Realtek Semi High Definition Audio Audio Device : EVGA GM204 High Definition Audio Controller Audio Codec : nVidia nForce4 Intel Edition CPU to PCI Bridge Serial Port(s) : 1 Parallel Port(s) : 1 Disk Controller : ASUS Lynx Point 6-Port SATA AHCI Controller USB Controller 1 : ASUS Lynx Point USB xHCI Host Controller USB Controller 2 : ASUS Lynx Point USB Enhanced Host Controller #2 USB Controller 3 : ASUS Lynx Point USB Enhanced Host Controller #1 SMBus/i2c Controller 1 : Intel ICH SMBus Printers and Faxes Printer : Send to Microsoft OneNote 16 Driver (1200x1200, Colour) Printer : Microsoft XPS Document Writer v4 (600x600, Colour) Fax : Microsoft Shared Fax Driver (200x200) Printer : Brother HL-L2380DW series (600x600) Printer : Brother HL-L2380DW series (600x600) Scanners and Cameras Scanner : Microsoft Brother HL-L2380DW series [30055c6cd64f] (Scanner, USB) Scanner : Brother HL-L2380DW LAN (Scanner, 600x2400, USB) Peripherals Media Player : SanDisk Extreme (58.41GB) Network Services Network Adapter : Realtek PCIe GBE Family Controller (Ethernet) Wireless Adapter : TP-LINK Wireless USB Adapter (802.11n (HT), AES-CCMP, 300Mbps) Operating System Windows System : Microsoft Windows 8.1 Professional 6.03.9600 Platform Compliance : x64 Performance Enhancing Tips Warning 2513 : TPM not detected. Some security features are unavailable. Tip 2 : Double-click tip or press Enter while a tip is selected for more information about the tip. |
Re: PT First Crashes on open
Are there any error messages that appear before the crash? -Tope |
Nope. No error messages. I didn't even get a bug report this time.
This time it stopped at installing plugins. I haven't installed any, I don't even know how. |
Brian Windows 11 Pro | macOS 12 Pro Tools 2022 benonistudio.com Youtube Channel - benonistudio Plugin Deals @benonistudio |
Mine crashes on open too. I have a Scarlett Solo, I'm on a MacBook Pro. It's not a huge deal for me. It doesn't crash on startup every single time but it does sort of often. When it does I have to force quit and start it again. It always has worked after at least a couple force quits. Still weird tho honestly and concerning.
Macbook Pro. MacOS Sierra version 10.12.5 Retina, 13-inch, Early 2015 Processor: 2.7 GHz Intel Core i5 Memory: 8 GB 1867 MHz DDR3 Focusrite Scarlett Solo Generation 2 Pro Tools First 12.3.1 |
Interesting that you too use the Scarlett Solo. When I first began recording I had a problem where Pro Tools was recognizing my interface as a separate input and output and I had to download an updater from Focusrite's website. Focusrite should be notified about this because it may be a problem with the Solo. Does anybody know how I could contact them about this? Maybe they could take a look at this thread.
First things first do not install the driver that came with the Scarlett if you are using pro tools. They have a separate driver you have to download off the pro tools site for it. Secondly if you don't turn up the interface settings in the control panel to the highest quality possible pro tools may or may not recognize your hardware. And if it does you'll hear nothing but static and white noise in your outputs and on your inputs. I've already told focusrite and guitar center about the issues. When the Scarlett works it sounds good but it is not at all compatible with pro tools without a headache
PT crashes when trying to open | ptr22 | Pro Tools M-Powered (Win) | 0 | 10-25-2010 06:30 PM |
002 crashes when trying to open pro tools | Shawnblack | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 2 | 06-11-2007 12:13 PM |
Help! Crashes when trying to open PT! | cerebral | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 2 | 02-05-2007 06:52 PM |
Pro Tools 6.4 crashes whenever I open it | johnmichaelhruby | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 1 | 10-21-2004 05:45 PM |
