Old 08-19-2016, 05:19 PM
vr_fox vr_fox is offline
Default FireWire 1814 broken inductor
I have a FireWire 1814 and the Inductor I7 broked i don't why, anyway. The ferrite core got broke.
The value is 470uH.
Height 15mm
Diammeter 15mm
But i need to know the impedance to buy a new one.
210 Ohms
377 Ohms
etc
Anyone knows this value.
Yes the value was 470uH i wrote it wrong
Thank you
Old 08-19-2016, 05:35 PM
Default Re: FireWire 1814 broken inductor
The value is 740uH.
Height 15mm
Diammeter 15mm
210 Ohms
377 Ohms
etc
Thank you
740 uH, you mean 470 uH?
What is this doing? A power supply filter choke? It's not impedance that is usually quoted (or you'd need to spec a frequency). It's DC resistance, so if you are worried about it measure the coil of the one you have with a multimeter.
What will matter is getting one that fits with the same mount type however this one is mounted. Look though DigiKey and Mouser for what you need.
Old 08-19-2016, 07:06 PM
This are the Inductors 470uH in mouser.
http://www.mouser.mx/Passive-Compone...yzvqm3Z1z0x280
I did measure the coil but its broken and measure 8 Ohms.
You can see the photos.
Old 08-19-2016, 07:15 PM
This is the Mouser list of inductor 470 uH 14 -16 mm (same size as original)
You can see in the photos that the core is broken. I mesure the impedance and its 8 Ohms, but don't know if the value is wrong because is broken. It also measures 364 uH.
No other way than the Firewire 1814? shultzee13 Pro Tools M-Powered (Win) 4 08-12-2008 12:54 PM
003 vs. M-audio firewire 1814 legacygone 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 2 01-11-2008 07:41 AM
Black Box AND Firewire 1814.... dillon99999 Pro Tools M-Powered (Win) 1 10-31-2006 07:01 AM
Mac Pro 2.66, Firewire 1814, 10.4.7 Imagine Pro Tools M-Powered (Mac) 7 09-21-2006 10:13 AM
Firewire 1814 Bill Pillmore Pro Tools M-Powered (Mac) 0 11-08-2005 04:38 PM
