C|24 becomes unresponsive
About once or twice every few months my C|24 will just become unresponsive. The display works, faders move with automation but they'll not write automation and will move right back to what automation is written in the session. Nothing will get it to work except a hard power off/on. Can't seem to recognize if I'm doing anything to make it happen.
I've seen where some say it's the power supply so I bought a new one...but it still happens. No big deal when I'm working alone...but it's not good when it happens while recording or editing with a client. Thanks for any ideas. |
Re: C|24 becomes unresponsive
Just the faders become unresponsive? What about all the other buttons?
If just faders then I would suspect grounding. Does it seem weather/humidity related? shoes etc. you are wearing? Make system the system and operator are suitably grounded. |
Have you tried recalibrating the faders and running all the tests?
Dave Marsden UK |
I have a D-Control but regularly use a C24 and I've seen this. Only way I've found is to switch it off and on again. The fault I've seen is that the whole board (buttons, everything) is unresponsive, it wasn't just a fader touch issue. Not a useful answer for you, but your one isn't unique!
Pete |
Buttons and faders...everything. Just seems random. I'm in Houston so humidity is always a factor here...but doesn't seem to follow a pattern that I see.
I live 50 miles from the Gulf of Mexico! I have recallibrated numerous times. Every now and again one fader will become unresponsive and have to recalibrate and it fixes the problem. But can 't recalibrate if everything is frozen. I'll go back and do all that. Thanks Marsdy.
That sounds like what Peter was saying and not the touch fader issue I was suspecting. And anyhow in the Houston area I would expect less touch fader problems unless you have HVAC pulling the humidity down crazy low.
1. Turn the C24 off. 2. Press and hold SELECT, SOLO and MUTE on fader channel #1 while powering the C24 back on. 3. Launch ProTools and visit SETUP menu > Peripherals > Ethernet Controllers. 4. There, un-check “Enable” then check “Enable” again. This will make ProTools rescan for the C24. 5. When scanning is complete, choose the C24 as the first unit. You’ll be promted that the firmware version does not match. Allow the firmware to be updated.
Dave Marsden UK |
No problem. If that doesn't solve the problem then I guess you've got a hardware fault maybe?
Dave Marsden UK |
D-Command unresponsive | DaleB | ICON & C|24 | 2 | 03-23-2013 01:51 AM |
M-Box is Unresponsive | TheForgottenXVII | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 2 | 12-18-2009 05:22 AM |
7.4 becomes unresponsive | Ed Douglas | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 1 | 12-20-2007 12:09 PM |
unresponsive server | abstech | Aspera DigiDelivery | 0 | 01-10-2007 02:20 PM |
Unresponsive Automation | NK | Pro Tools TDM Systems (Mac) | 1 | 11-08-2001 10:00 AM |
