Slightly Rude Compressor
I posted this questions a while ago in another forum with no solutions going.
Now I post it here as a plea to modify the plug-in on future versions: Give it a separate threshold control or a gain control capable of upping AND lowering the output level (instead of the make up). 1-After thinking that this compressor was awful on the 2 bus I went on and read the manual and realized that the rudeness control was not the threshold Now I´m stuck with another problem, worse, if you will... being that the Input is the threshold now when I get the sound I want (with rudeness at 20/30%) the output is clipping crazy... Why didn´t they include an output level instead of an only-go-up make up gain? If anyone has any ideas about a workaround to this, I am all ears. Because I´m surely out of ideas! The thing is that this particular plug-in overloads the 2 buss before actually doing a dB of compression on low "rudeness" settings (unless you crank the "rudeness" control to very high settings which makes the mix pump like crazy), and since it has no separate threshold or output level there is no way of getting a nice 2 bus thing going on without having so much input that the output is overloading all the time. Trust me, you don´t need the make up gain control for this plug-in on 2 bus compression! It just seems that the threshhold is too high! I am sorry, I thought you were familiar with the thing because it was on your website with like-you comments a while ago. Does anybody remember Erick´s (designer) last name? He was pretty well known (and hated, poor guy) here and on Musicplayer. I don´t really expect to find a solution, maybe someone to complain to! This is when you really wish the thing had a hood you could lift to get someone to do a mod. |
Re: Slightly Rude Compressor
I have no experience with the plugin, but if it lacks a control that lets you reduce its output, pulling pack on the track fader should do the same job.
Mac mini M2 16GB RAM macOS 13.4.1. PT Studio 2023.6. Topping E30 II DAC, Dynaudio BM6, 2 x Artist Mix, SSL UC1, Control on iPad. |
No Slightly Rude Compressor??? | TOM@METRO | AAX Plug-ins | 21 | 06-05-2020 11:43 AM |
Slightly Rude Compressor | stainless | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 0 | 08-11-2006 07:53 AM |
Slightly Rude Compressor | Peter Duemmler | Pro Tools TDM Systems (Mac) | 3 | 11-26-2004 08:52 AM |
Slightly Rude Compressor | ajazzie | Pro Tools TDM Systems (Mac) | 0 | 10-04-2004 04:55 PM |
Anyone Try/Buy The "Slightly Rude Compressor?" | Soul For Sale | Pro Tools TDM Systems (Mac) | 1 | 08-25-2004 12:33 PM |
