Presets missing for non-Digidesign plugins
Presets for all plug-ins that are not Digidesign plug-ins show <factory default> and nothing else. Only Digidesign plug-ins are showing presets. I deleted preferences and databases using the Tech Support Utility, and the problem remains. It seems that Pro Tools is looking for the .tfx file extention, but only Digidesign plug-ins use that extension. Is there anyway to get non .tfx presets to be recognized?
Re: Presets missing for non-Digidesign plugins
There are a lot of third party plug-ins that don't show presets from the same box where <Factory Default> shows up. It really is up to the third party plug-in developer, not Digi, to make that happen. For instance, PSP, Waves, and Izotope don't use the "Digi format" for presets but McDSP does. Usually, but not always, the third party plug-ins will have their own access to presets (usually another button somewhere on the plug-in).
Which plug-ins can you not find the presets? Greg |
Digi could always go the extra step with a little more plug-in integration testing though, at least if it's claiming to have a flagship sequencing program. Yes, there are some plug-ins such as most Native Instruments ones (with the exception of Pro-53) that have internal selection of presets.
Non-internally, all plug-ins that weren't installed by the Pro Tools 8 media did not have any presets available. Here is a list of some of them: Trilogy SampleTank2 Native Instruments Komplete 5 (all instruments) East West Syphonic Orchestra Silver Edition Etc. One solution to obtaining non-user presets that worked for some of them such as Pro-53 was to load them into an instance of Native Instruments Kore. One problem though, is that user-defined presets are usually what are missed most. These are unattainable for some instruments such as Trilogy, SampleTank2 and others. It should be noted that Cubase and other sequencing programs show presets for all of the plug-ins above. I'm basically trying to make a clean transfer of my tracks from Cubase 4 to Pro-Tools 8 without having to re-tweak the presets I came up with earlier. |
I suppose I could replicate the user defined preset settings by analyzing screen shots of the plug-in instances in Cubase...
balveniediggz,
You need to complain to the 3rd party plug-in provider (NI, etc). Their developers have been given the same guidelines as all of the other plug-in developers. They chose not to expose plug-in presets inside PT, not Digi. Another possible solution for you is to use the Fxpansion VST to RTAS wrapper so you can use these plug-ins as VST's (where you will see the presets) inside PT and save the presets in the .tfx format. Greg |
or you could copy and paste the presets into plug in folder>
program files>common>digidesign>dae >plug in setting hope this helps
Gear> C8, 002, Trigger Finger, Kontrol 49, Apc 40 SW > Pt 8, Reason 5, Recycle 2.1, Ableton Live Suite 8.02 Plugs > All Registered plug in's & Vinyl out the wazoo. Mp3 sucks |
I've already used Fxpansion VST to RTAS wrapper, otherwise I wouldn't have even seen any of the VSTs in Pro Tools. Using the wrapper allows you to use the VSTs as RTASs, and you cannot see the presets. You can, however, save new user presets in Pro Tools but this defeats my stated objective of making a "clean transfer of my tracks from Cubase 4 to Pro-Tools 8 without having to re-tweak the presets I came up with earlier". |
I thought the same thing, Ozone 3's presents vanished after I upgraded to PT8, they where there the day before with PT7.4. Then I read the manual for Ozone and looked to see where it stores its presets. Then I dropped Ozone onto a track, clicked "select preset folder", pointed it to the correct location, and I had all of my presets back.
Now, what this suggests is that the PT8 install somehow screwed up the mapping for non-digi plugin presets. It wouldnt hurt to investigate how you can point your non-digi plugins to their presets, post-PT8 install. |
It is possible that re-installing some of them, and selecting to install as RTAS instead of just VST could resolve the issue, although it's a shot in the dark whether or not tfx format presets would be created... and it's a rather painstaking process... |
Plugins Missing Presets PT 10.2 | anthonymunoz | macOS | 2 | 06-01-2012 07:55 PM |
Instrument Presets for plugins are missing | RuffinMedia | macOS | 6 | 06-09-2011 08:38 AM |
Eleven LE presets missing | SteveFireland | Pro Tools M-Powered (Win) | 3 | 12-12-2009 04:02 AM |
Presets missing for plugins | balveniediggz | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 6 | 12-29-2008 06:11 PM |
Digidesign Factory Presets Missing | zimbu | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 1 | 12-15-2008 09:50 PM |
