Old 06-03-2007, 11:06 PM
BiggiT's Avatar
BiggiT BiggiT is offline
Default Recorded MIDI is ahead in playback
So..just setup a 003 (the mixer) and I suddenly have this problemos with th Le MIDI...
never seen before problem..
When I record a midi (Expand) or just what ever,, and in the background I have audio channels,,,ok.. very basic.. BUT,, when I play back ,, the MIDI what i just recorded is like a 250ms ahead... WHATS UP WI DAT.....?????
HELP
BT
Old 06-04-2007, 02:00 AM
Default Re: Recorded MIDI is ahead in playback
Have you entered any 'Offsets' that contradict those of which were recorded in the first instance?
filosofem
Aaron Mulqueen - 001 HD Native
Old 06-04-2007, 09:34 AM
BiggiT's Avatar
NOP... everything as was..
there used to be a 002 Rack the day before..
what i did was this..
Uninst PT7 that was and everything with it
inst PT7,3 from cd
upgraded firmware on 003 (required to)
upgr PT7,3 to cs3
no 3rd party plugins installed (yet)
and my Computer has plenty of everything
and is certified "PT"
this is a odd problemos couse I tried a simple midi recording ,, just with a click on a aux and a instr track with xpand (very simple) and picked my keyboard in beat with the click.
And in the playback the midi I recorded is ca 250-500ms ahead of the click. WAAZZZUPPP WITT DAAT ?
Any help is appr
Regards
Odd Problemo
Old 06-04-2007, 06:20 PM
Hmmm... could you give us some detail about your Pro Tools rig?
filosofem
Old 06-05-2007, 08:20 AM
BiggiT's Avatar
screenshot of prob is on
www.hljod.is/PT
this is as simple as i can put it... aux track with click
and a instr trk with xpand and proj is at 120bpm
and what u see is when i tapped the keyb in beat of the click (and "no!!"inp quant is not on)
ps..
Yesterday I talked so some guys at school (VFS.com),, and many are having the same prob after upgr to cs3,,, (at least we wanna link it to cs3)
Something to do with that Digi resantly changed the midi code to nine hundred somethin pulses...int the midi
BT
Old 06-05-2007, 08:14 PM
Interesting, I just did a first time MIDI recording with AIR's Velvet since the cs 3 update and I have no such problems. In fact, she's running better than she ever has.
Mbox 2 Pro (MTS) 7.3.1 cs3
ASUS K8N-DL 265 Opteron AMD Quad
Are you using a Mac or PC? Have you tried rolling back the revision?
filosofem
Old 06-06-2007, 10:19 AM
Sonny in London Sonny in London is offline
I just want to add that I've had this same problem, though intermittently, with my MBox2 Pro on my Windows machine. Very odd.
Sometimes, even the click is unstable and unusable, so I created a midi track and penciled in crotchets (quarter notes) and triggered a clave on XPand, only to find that that plays back skew-whiff.
However, more important at the moment, is that sometimes recorded audio is playing back ahead of time!
After tracking and then trying to overdub, I find that the recorded sound is out of sync and I have to nudge it forwards by about 3000 samples. Insane.
Sonny
Old 06-06-2007, 11:17 AM
DigiTechSupt's Avatar
This sounds suspiciously like the MIDI problems created when the WinXP dual core hotfix has not been installed. If you're on a dual-core AMD processor, you should also apply the AMD dual-core optimizer patch.
Is this possibly the case? Is everyone experiencing this on a dual-core system?
Info on where to get those updates can be found in the Win XP/ Pro Tools 6.x/7.x General Troubleshooting thread.
Avid Audio Tech Support
Support FAQ
No sound when playback recorded midi at VI RockingGhost Virtual Instruments 3 05-18-2014 04:09 AM
Recorded Midi Wont playback JesseZaverucha 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 15 01-22-2013 11:07 AM
Audio Recorded from MIDI track ahead of the beat/grid CalebB macOS 1 10-22-2012 11:03 PM
recorded midi is ahead by 1/32 note! PhilBuckle Pro Tools TDM Systems (Mac) 3 01-24-2009 09:29 PM
tracks playback 1.4 seconds ahead KenSluiter Pro Tools TDM Systems (Mac) 5 01-12-2005 10:52 PM
