Old 01-12-2005, 11:20 AM
KenSluiter's Avatar
KenSluiter KenSluiter is offline
Default tracks playback 1.4 seconds ahead
I'm adding some last minute bkgd vox and percussion onto a track and when I play back the tracks, the audio is roughly 1.4 seconds ahead of where I played.
For example, if I play a tambo along with a track (in good time), when I playback, the tambo is way ahead of the beat.
I do these kinds of things all the time, but suddenly today it's not playing back these tracks in sync.
I haven't changed any preferences or anything.
Anyone got any ideas?
Thanks,
Ken Sluiter
Old 01-12-2005, 12:28 PM
putney putney is offline
Default Re: tracks playback 1.4 seconds ahead
Thanks,
Ken Sluiter
More info needed.
"What's the best mic under $100."
Old 01-12-2005, 01:10 PM
Seeee Seeee is offline
yeah.. more info. if you have 5 plugs in and it routed to an aux track with 5 more plugs, etc then I can see latency being an issue BUT.. more likely you need to trash your digisetup preferences (if in os9) cause something is corrupt.
Old 01-12-2005, 06:00 PM
KenSluiter's Avatar
I quit PT and re-launched and now everything seems to behaving properly.
On a related note, I'm trying to lay down an organ part from my controller into a MIDI i/O and into Sampletank.
I keep getting noticable latency betweeen when I strike the note and when I hear it.
I tried using Reason thru re-wire and got the same thing.
Again, I use the MIDI side of PT regularly and have never seen this behavior.
Any ideas?
PT 6.4
HD2 Accel
Mac 10.3
Old 01-12-2005, 07:03 PM
DigiTechSupt's Avatar
Hi try using a smaller hardware buffer setting when you are using Rtas plug-ins its sizes will effect the latency you are experiencing. If you are using HTDM plug-ins you may want to try using the low latency StreamManager here . Also plug-ins on the master fader can delay the entire mix. Look ahead limiters like Maxim and Mater X are prime examples. I hope this helps.
Thanks,
Digidesign Tech Support
Avid Audio Tech Support
Support FAQ
Old 01-12-2005, 10:52 PM
KenSluiter's Avatar
That did it!
Thanks,
Tracks record ahead of beat? drumzalicious macOS 5 05-21-2020 11:19 AM
No playback on recording over 30 seconds ditto Pro Tools SE and Essential (Win) 0 12-31-2011 04:27 PM
RTAS Instrments tracks playing ahead Touchwood Studios Pro Tools TDM Systems (Mac) 1 12-18-2007 10:08 AM
Recorded MIDI is ahead in playback BiggiT MIDI 7 06-06-2007 11:17 AM
Buffer under/over run after 1.345 seconds of playback!? Silence 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 3 07-19-2002 11:15 PM
