PORTABLE VOCAL BOOTH
Hey, have any of you guys checked out www.vocalbooth.com and www.whisperroom.com ???
Ive been looking for a portable vocal booth because i live in an apartment. Im interested in buying one. What do you guys think??? |
Re: PORTABLE VOCAL BOOTH
hmm well i always hate it when you can't find prices on a website - vocalbooth.com seem rather shy about it
and the other site freaks my browser out
www.piersgibbon.com www.soundcloud.com/piersgibbon VOICEOVER - Avalon 737sp/Focusrite Saffire Pro 40/Neumann + Rode inside an Esmono voiceover studio (+ Source Connect, Prima LT, Sonifex TBU, Sonnox plugins) Record: MBP 13 inch mid 2012, 2.9 ghz i7 8gig ram, PT 11, GDrive Professional Ext Hard Drive Backup:15 inch early 2008 MBP, OSX 10.10.2 (+Windows 7 PC running Audio TX isdn and tbu codec) Edit: PT Express 10.3.4 on 13-inch, Late 2010 MacBook Air, OS X 10.10.4 |
We have a whisperroom vocal booth at my work, if you can afford it, they're totally worth it. Well consrtucted, easy to put toghter, very very quite, and completely portable, the one we have rolls on casters, I recommend it completely. The vocalbooth.com silver series, starts at 1,700 a little cheaper than whisperroom, and I'm sure they make a great room too, but I have no experience with them. Hope that helps, BTW if your handy when it comes to carpentry you could certainly fashion a booth toghter with a little research for probably half the cost. In fact i'm moving to a new place right now, and a buddy of mine who's got a degree in acoustiocs from Columbia college in Chicago, is going to help me construct a a islotaion booth from scarth, I'll let you know what we did, and what it cost if you want. We're going to make a room inside of a room with 3sheets of drywall for all the wall, I'm going to then roominate the space with a auralex kit, a tight door, and a little window, and the whole thing will be up off the floor, My friend insures my we can do the whole thing for a couple hundred bucks, I'm excited to see how it turns out.
PowerMac G4/1.2ghzPowerLogix Panther OSx 10.3.4 Digi002/Protools 6.4/DVtoolkit Certified Protools6.x Post-Production Operator |
You could save a bundle by contructing one of these yourself....
The Burner |
now I'm sure i'm not the only person who wd reeeeeaaaaaallly appreciate it if you cd let us know how that project goes Scott....open access source code drawings 'n all ; ) ...
seriously that would be great i finally found the price info on vocalbooth... "Customer service and your satisfaction is our number one priority.* With three levels of systems available we want to make sure you receive the best fit for your needs.* With the fluctuating economy we want to be able to give you the best price possible.* Call us for a personal consultation and price quote. " i dunno..i just dont like it when they do that
I haven't read this yet, but check out this link:
http://srd.yahoo.com/S=2766679:WS1/R=5/K=vocal+booth+construction/H=0/T=1049226256/F=8affe60c761857e baf1a021766a61108/*http://www.hip-hop.com.au/production/tips/vocalbooth.htm you may find it interesting. Also...there is a cheap book called "Basic Home Studio Design" (by Paul White) that you can buy for like 7 bucks from amazon.com that outlines basic construction techniques for all kinds of studio structures.... check it out homey
The Burner |
hola Tyme,
I got a Whisperroom about two months ago, just a little 4x4, for use in my loft apartment in Berkeley. I could not be happier with it. Not only does it reduce outside noise into insignificance, but it keeps the performance "in the box" as well, which seems to help performers give it there all. Self consciousness goes away, neighbors are completely oblivious. It is easy to put together, but don't plan on doing it alone. Each piece is pretty heavy. Also, WR's customer service is excellent. I highly recommend getting the window-in-the-door option. Hope this helps. Opus F.
The church is near, but the way is icy. The tavern is far, but I will walk carefully. |
Ok It took me awhile to get my stuff together but it's done. My friend and I finished the vocal booth this weekend. PICS ON MY SITE TO COME SOON here's what it took
1 night to buy materials at Home Depot and load them into to the new studio (I'm moving in 2 weeks) 1 11:00am- 9:00 PM Sat. and 4hours of my friend working solo to finish the door. The Dimensions are roughly 4"wideX5"longX6"tall Heres what we did: no real research I followed my friends advice all the way like i said he's got acoustics degree from Columbia and I trust him Phase 1 we constructed a platform made from 2X6 laying flat on to a 3/4" peice of plywood ,the platfrom was attched to 5,3" casters(one in the middle) a 2X4 cross was placed across the undercarriage of the platform We constructed 3 walls of MDF and then the MDF ceiling. We had to contrust the long walls by using 2 cuts, (obviously, you can't buy MDF,drywall, plywood in sheets other than 4X8) Once we had the outer 3 walls and Ceiling attached to the paltfrom we moved to Phase 2 The floor was then layerd with a 1/4 inch sheet of rubber flooring material, and then another sheet of MDF, weather stripping was placed on the 4 side corners ot the MDF flooring Phase 3 DRYWALL(sheetrock whatever...) We then lined the 3walls and ceiling with 2layers of 5/8" drywall WARNING !!!!!!!THIS BOOTH DESIGN WEIGHS A MASSIVE +1/2 TON Phase 4 The Door It;s made just like the walls (MDF drywall,drywall) except in the middle of the 4th door wall a 2'permanent wall comes out to the center and a long hinge holds the the 2'door in place. The door is really cool all 3 layers of MDF and Drywall interlock on the hinge side and latch side. Phase 5 Auralex, I bought the cheapest kit $99 32 tiles I put velcro on the backs so I can arrange them as I please That's pretty much it , we used 4 tubes of caulk and a roll of duct tape on all the seams. weather stripping on the door, no window, no vent, open the door if you need to breath. There are plywood pads under the wheels to keep them from going through the floor. 4 battery operated Touch Lights for light. Total cost $363.62 Materials $99 Auralex kit $160 for my friends labor (almost 20 hours of total work/shopping/cleaning/load in) BTW this both is much quiter then the Prefab $2000WhisperRoom at my work, no numbers to prove that but I can totally tell the difference.
The one I have I bought from a door-to-door salesman and is 8'x8'x10' and folds down to the size of breifcase. It is from the Acme Iso Booth Company from Walla Walla, Washington. I can't remember the salesmans name, but he had an orange bill.
NP P.S. Mine also has an elevator. |
Ok so I forgot this topic was called "PORTABLE voal booth" So mine's not so portable, however it does move around on the floor with ease, I can move it wherever I want no problem. It' s like pushing a compact car in neutral. The problem with this design is that we estimate that it can only be taken down and put up 3 or 4 times before major problems might start.
FS: Clearsonic Iso E Portable sound booth | AV Pro | Buy & Sell | 0 | 05-16-2013 04:15 PM |
Vocal Booth? | Bart HLH | General Discussion | 5 | 03-02-2007 05:48 PM |
PORTABLE VOCAL BOOTH | Big Tyme | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 6 | 04-03-2003 06:06 AM |
Best Portable Vocal Booth - Under $700 | Kevin Genus | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 2 | 03-26-2003 12:22 AM |
Vocal Booth | smrp | Tips & Tricks | 5 | 05-31-2000 01:06 PM |
