Go Back   Avid Pro Audio Community > Pro Tools Software > Pro Tools 2018
Old 03-08-2018, 09:44 PM
thebeatinventor thebeatinventor is offline
Default SSL Duende Channelstrip Crashing in ProTools 2018.3
I just installed ProTools 2018.3 and now the SSL Duende Channelstrip is crashing and quitting my sessions the same way it did in 12.7 and above. I got it to work in 12.8 with no issues and since have been using it until the recent 2018.3, some of the projects I reopened that has the Channelstrip inserted now just crash on playback....SSL claims it works in High Sierra/ProTools 2018.1 and 3 with no issues but it’s been horrible on my end. Any others willing to test or have the same issue? I’m disappointed in SSL, although they are moving into the digital age with their control surfaces which are software based, you would think they would update and focus heavily on their plugin line and make them compatible for users more than ever now that plugins are so widely used. There are other SSL style strips out there but I love the sound of the genuine SSL brand Channelstrip....
Old 03-08-2018, 11:44 PM
wmcintyre wmcintyre is offline
Default Re: SSL Duende Channelstrip Crashing in ProTools 2018.3
Same here.
Old 03-09-2018, 07:39 AM
john1192 john1192 is offline
SSL says it works in 18.3.0.285, the latest version ??? it was just released yesterday !!!
i will test this today - but just running Sierra 10.12.6 .. i assume you have SSL Duende Channel Strip 5.1.3 right ??
OS 10.12.6 for PT 11.3.2 & 12.4 & above
Mac Pro 6-core 3.33ghz (2012) 24gb ram 256gb SSD
Macbook Pro july 2014 2.5ghz 16gb ram 512gb SSD - OS10.12.6 - PT 12.4 & above
lynx AES16e-SRC & Aurora 16
Artist Transport & iPad - Pro |Control - EuCon 3.7 (older Euphonix Branded MC Transport)
Old 03-09-2018, 12:19 PM
s.d. finley s.d. finley is offline
I am not using the duende channel strip, but am using the bus compressor with no issues.
sdf
sugarhillstudios.com
Old 03-09-2018, 12:36 PM
hi, yeah the Bus Comp never had any crashing issues like the Channel Strip in ver 5.1.1 and ver 5.1.3 ... hoping for update soon !!!
Old 03-09-2018, 12:37 PM
octatonic octatonic is offline
Have you tried reinstalling V5.1.3 64 bit?
I have Pro Tools 2018.3 running here with V5.1.3 with no issues.
Old 03-09-2018, 04:20 PM
Yes I did re-install 5.1.3 64 bit version, that didn’t help.....did you try adjusting parameters on the ssl Channelstrip while the session is in playback? That’s usually when it quits and crashes....
Old 03-09-2018, 04:23 PM
hey Beat, are you running HD or Vanilla ??? i assume non-HD but better to ask ..
Old 03-09-2018, 05:16 PM
Vanilla....
Old 03-09-2018, 07:24 PM
TNM TNM is online now
hmm just checked 5.1.3 strip, engaged every function then disabled, moved every knob. Inserted a drumstrip in it's place, then put the channel back and copied it over to 8 other tracks and opened the gui's of all. No crash.
Perhaps there is some corruption somewhere with the OP's install, sadly.
download easy find from devon technologies. Make sure hidden files is ticked and search within files.
Do a search for the word duende.. delete everything (double check no system files) including the installer bom files.
Restart computer, and reinstall. Restart again. then try use.. i think will be ok.
problem is though, we have no idea what the OP's setup is. What OS?
System 1: iMac i7 3.4ghz quad core, OSX 10.12.6, 32GBRam, 2TB Internal Apple HDD 7200 rpm, 256GB internal Apple SSD, TBolt 7200rpm G-Drive, Pro Tools 2018.3,, Cubase 9.5.2, UAD Apollo8 TBolt Quad x2, UAD satellite Octo TBolt x2, TBolt 512GB Lacie SSD, ATI 6970M
System 2: Macbook Pro Retina 2.8ghz i7 quad core, OSX 10.12.6, 16GB Apple Ram, 1TB Apple SSD, 1TB Thunderbolt SSD, Logic Pro 10.3.3, Cubase 9.5.2, Pro Tools 2018.4, Apollo Twin Duo, Nvidia 750M/Intel Iris Pro
Getting a lot of crashing with 2018.1 James Lugo Pro Tools 2018 25 04-04-2018 01:53 PM
SSL Duende Channelstrip and Pro Tools 12.8.1 thebeatinventor Pro Tools 12 6 12-03-2017 03:04 PM
SSL Duende Channelstrip and Pro Tools 12.7.1 thebeatinventor Pro Tools 12 19 10-18-2017 01:38 PM
Pro-tools 12.8 and SSL Duende Channelstrip thebeatinventor Pro Tools 12 21 07-18-2017 09:07 PM
SSL Duende ChannelStrip Crashes john1192 Pro Tools 12 17 12-17-2015 07:17 AM
