Old 03-20-2018, 01:27 AM
silverhammernz silverhammernz is offline
Default Strange bounce behavior 2018.3
Bounced 10 tracks (songs) in one long file, first 2 in bounce had brief fade ins on one side of the stereo only that weren't in the original arrangement, other songs ok. This also happened in bounce the night previous as well.
Several days later, after discovering fault, same arrangement and plugins bounced again this time no problem. Plugins were on a master channel, pro limiter, some Slate stuff, Console1 and Fabfilter Prol2. Not come across this problem ever before.
Macbook Pro High Sierra, PT 2018.3.
[COLOR="Gray"]
MacMini M1 16G Ventura
Apollo Twin, Apogee Symphony Mk1 w/Thunderbridge
Les Paul Goldtop 1968 (from new)
www.larrykillip.com
Old 03-20-2018, 04:54 AM
Drew Mazurek's Avatar
Default Re: Strange bounce behavior 2018.3
Prefs/Operation/Auto Fade In/Out.
Saved per session.
Could be this.
www.drewmazurek.com
Old 03-20-2018, 08:39 AM
OP says it's on one side only, so maybe not auto-fade. Have not heard of this, but I'd be curious if problem happens when some of those plugs on the master bus are de-activated; in particular I'd look first at the Slate plugs. Just a thought...
http://www.richbreen.com
Old 03-20-2018, 12:22 PM
Thanks for replies, the problem was only discovered a few days after, then I tried to replicate it with same settings, same arrangement but problem was gone. So I didn't get a chance to test deactivating plugins one at a time. 10 songs, approx 2 secs apart, only the first 2 exhibited the problem.
A picture here: https://www.flickr.com/photos/471316...posted-public/
[COLOR="Gray"]
www.larrykillip.com
Old 03-20-2018, 04:04 PM
Slate FGX in the session?
www.drewmazurek.com
Old 03-20-2018, 04:14 PM
Sardi Sardi is offline
Yeah, sounds like the panning bug that plagues a lot of FG-X users.
Either don’t use it or add a second of silence at the start of the session then trim the audio after bouncing it.
Old 03-20-2018, 07:58 PM
Yes, Slate FGX on every channel, which might explain why some tracks were affected and some not. Hadn't heard of that one..hmmm.
[COLOR="Gray"]
www.larrykillip.com
Old 03-20-2018, 08:05 PM
TNM TNM is offline
it's a known bug with FG-X
Are you sure you are using the very latest build? Logic users were going crazy with fades on bounce with FG-X but slate apparently fixed it.
Just checked, latest FG-X is 1.4.0
I'll do a test myself and see how I go. I never use FG-X anymore even though installed, i find it inferior to ProL2 and quite a few others.
- Apple Mac Studio M2 Ultra/64gb/UA Apollo x 3+Adat x 3/UAD Satellite x 3/OS 14.41/PT 2024.3/Nuendo 13/LogicX
Old 03-20-2018, 08:30 PM
DetroitT's Avatar
DetroitT DetroitT is offline
the next update soooooon.
i know it's old.
Old 03-20-2018, 08:58 PM
I am usually up to date with Slate stuff, but I will check. The fact it didnt happen several days later with the same set up was perplexing. If it was consistant I could have simply bypassed plugins until the problem disapeared. Appreciate all the input, better to know what I am dealing with. If I cant trust FGX then it’s outa there.
[COLOR="Gray"]
www.larrykillip.com
HD I/O Strange behavior Thuneau Pro Tools TDM Systems (Mac) 1 12-09-2011 03:01 PM
Strange ADC behavior? TiPo Pro Tools TDM Systems (Mac) 11 03-13-2007 10:55 PM
what about this strange behavior? AuraMaris Studio Pro Tools TDM Systems (Mac) 4 10-25-2004 02:11 PM
strange low-end behavior viaspiaggia Post - Surround - Video 9 08-09-2004 01:01 PM
Strange PT behavior agus Pro Tools TDM Systems (Mac) 0 10-26-2000 10:27 AM
