Go Back   Avid Pro Audio Community > Pro Mixing > Avid Pro Mixing General Discussion
Old 03-12-2018, 11:00 AM
Tommys Daddy Tommys Daddy is offline
Default Help Needed
I have an edited track of audio I am trying to bounce to disk, but this message keeps popping up. How do I correct this problem?
Sent from my SM-J327T using Tapatalk
Old 03-12-2018, 11:05 AM
Drew Mazurek's Avatar
Default Re: Help Needed
Tough to diagnose on a forum.
Assuming path means disk path. Have you tried changing destinations?
Trashed prefs?
All sessions or just one? new sessions?
www.drewmazurek.com
Old 03-12-2018, 11:17 AM
YYR123's Avatar
YYR123 YYR123 is offline
This sounds like you need to double check the sessions output path.
The bounce dialog asks you which path you want to bounce. Path meaning which stereo output you want to bounce.
Outs 1/2 or any other outs available on you system.
Daniel
Old 03-12-2018, 11:38 AM
Trashed prefs?
one session.
Old 03-12-2018, 11:45 AM
Originally Posted by Tommys Daddy View Post
one session.
I tried changing the output path on that audio and none of them will let me bounce to disk. Any other thoughts?
Old 03-12-2018, 11:47 AM
This is what I have selected as my output...
Old 03-12-2018, 12:28 PM
one session.
So all is good on new sessions and other sessions.
Then make a new session and import session data to bring all your parts in.
Not sure why one session would exhibit this behavior, but this will get you going again.
www.drewmazurek.com
Old 03-12-2018, 12:58 PM
Tried to import the audio in a new session and still the same problem.
Old 03-12-2018, 01:06 PM
Try trashing all prefs.
http://www.pro-tools-pc.com/support/trasher/
www.drewmazurek.com
Old 03-12-2018, 01:08 PM
Any thoughts Drew? Thank you for your help!
Reamping help in PT 11 badly needed..... Kemper dudes needed!!! TheEdster75 Pro Tools 11 6 01-08-2017 08:38 PM
PT9 003 Help Needed Airspider23 Pro Tools 9 0 12-13-2012 11:34 PM
Help needed Please Hidden Sound Pro Tools TDM Systems (Mac) 4 09-28-2010 04:34 PM
help needed bryanpatrick 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 5 01-06-2004 10:18 AM
Help needed!!! CHRS 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 5 10-30-2003 08:59 AM
