Make MIDI editor track selection independent of edit window?
I'm working on a project where I need to be back and forth between the audio edit window and the MIDI editor window. Problem is, every time I click on a track in the regular edit window, the display in the MIDI editor window changes. I have to go back to the group list and select "show all track in group" for the group I'm working on, and it takes time and interrupts my train of thought.
I've looked long and hard at PT preferences and can't see anything that would affect this - am I missing something? Any thoughts would be greatly appreciated. Thanks, Myles
System 1: 2023 Mac Studio 64Gb RAM, OS 13.6, PT Native 2023.12, Metric Halo ULN-8, LIO System 2: 2021 M1 Mini 16Gb, OS 13.6, Native 2023.9, MH ULN-8 4d http://www.mylescochran.com |
Re: Make MIDI editor track selection independent of edit window?
I'm pretty sure that the Midi editor follows the "selected" track...
X Note that all opinions, observations, whatever, in this post are mine, unless I'm being mean or am wrong, in which case it's somebody else's fault. I do not work for Avid (their loss)...my only relationship with Avid is that of a customer (when I'm not too poor to buy stuff, like now)...and that hot administrative assistant...that's more of a "thing" than a "relationship" (that should keep them guessing for a while...) Just rockin'...what more is there? Bill in Pittsburgh |
you can turn off scrolling in the midi edit window if that helps. Also the shortcut to toggle between the midi edit window and edit/mix on mac is CTRL + the '=/+' key (similar to CMD + the '=/+' key to toggle between mix and edit)
sorry if that doesn't relate to what you're asking :) |
Yep, that's what I'm thinking. It would just be so nice to be able lock the MIDI editor so that it holds on to what you're working on...
track selection visible in edit & mix window | I&I | Pro Tools 11 | 0 | 06-29-2014 10:51 AM |
Linking Midi Editor With Edit Window | ROCKYIII | Pro Tools 10 | 0 | 05-26-2014 01:02 PM |
How do I link Edit Window & Midi Editor? | Lukehanigan | MIDI | 2 | 12-02-2009 05:40 PM |
C8 Follows Link Track Selection in Edit/Mix window | FluffyPost | ProControl, Control|24, Command|8 | 2 | 01-20-2009 08:44 PM |
Mix/Edit Window Track Selection | compmedia | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 0 | 05-12-2000 07:14 AM |
