Old 03-27-2013, 08:13 AM
Siegfried Meier Siegfried Meier is offline
Default Sync IO LCD Screen Brightness
Hey guys,
Just bought a used one of these - any reason why the main LCD screen would be so dim? I can barely read it...I've used these before and they weren't like this. Is there an adjustment? I'm not finding anything in the manual...
Thanks!
Sig
Old 03-27-2013, 10:25 AM
Default Re: Sync IO LCD Screen Brightness
I took it apart and reapplied new thermal compound to the resistor that attaches to the chip (since it was dried up and was no longer touching, and therefore getting very hot). Removed all the PSU and board connectors, and plugged in and out a few times. Then, used a phillips screwdriver to adjust the small potentiometer on the PSU, wiggled it back and forth and put it back where it was...and now the screen is nice and bright, as are all the other LED's and main power ring LED.
Appears to be oxidation from where it could have been stored. Some tips in case anyone else sees this kind of problem in their units.
Sig
Old 04-04-2013, 11:33 AM
antonis's Avatar
antonis antonis is offline
Good job!
Old 04-10-2013, 11:56 AM
;-D
Laptop display brightness increases when I run Pro Tools - why? iain_m Windows 10 06-20-2012 03:53 PM
System 5 Brightness Utility PhilippeCNA System 5 2 12-23-2011 01:36 AM
Advise on high brightness 15" monitor digidesigner VENUE Live Sound Systems 1 06-04-2011 07:33 AM
mouse not in sync with screen bryanbassett 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 0 10-22-2001 08:10 AM
Adjusting brightness of meters on 888? JaredV Pro Tools TDM Systems (Mac) 3 03-21-2000 09:10 PM
