#4011
Re: Best Desktops for PTLE
Done
Allen |
#4012
Now i am worried.Everything works fine but I am gonna remount it or bring it in and have someone do it.I might get a stock fan til someone here figures out the right way to mount it to the k8vse dlx board.I dont want to screw up my new pc!!! Especially after gettin 32+26 at 128 24 bit!!! Whats the best way to remove the arctic silver I bought for it?
Davec 1 results,32+68 at 1024 buffer,32+ 41 at 128 buffer both 24 bit |
#4013
Hi Allen,
I appreciate your post on what to buy as I'm currently upgrading my AMD Athlon 1.4GHz, 256MB DDR RAM to use with my Digi002Rack. I'm curious looking at your page 1 post that its from 2002... Is the list out of date? Is there anything other that we should be buying? Thanks Allen, just deciding to buy the 002 Rack was an obstacle. There's always a next obstacle to encounter. Take care, Brad |
#4014
RP |
#4015
Hint Hint!
Allen |
#4016
MadRock... I built almost an identical system to you however when i play back from certain sessions i get the Increase H/W Buffer size.... no plug ins ... and play back shows my cpu meter jumping around... i played another session and it ran fine then gave me a cant get data from firewire fast enough.... I had SP 2 then did a total reformat and started without any update same issue
Configuration. Asus A8ve-Deluxe AMD FX-55 Crucial Ballistix 1 Ghz DDR400 Seagate Barrucuda 7200 RPM SATA Drives PCIex Geforce 6800 GPU Digi 001 PLEASE HELP Anyone.. Derek |
#4017
ah,
Thanks guys, I'm now busy tracking this stuff down. any good "bundle" shop recomondations? Brad |
#4018
Have fun. Allen |
#4019
Hey Allen,
Here is my experience with installing a Zalman fan. I just installed my Zalman 7700cu onto a K8V-SE Deluxe on the weekend and got mine to fit great. At first I wasn't sure whether to use the backing plate that came with the Mobo (the metal one) or the one that came with the fan (black plastic one for 754 chipset). The screws that came with the fan did not thread with the mobo backing plate. It seemed that the metal backing plate was glued to the mobo really well and that we would have to use it. After some gentle manipulation, the metal backing plate popped right off. Getting the fan screwed on properly was a little tricky but fit just fine. Everything is stable and whoa!!!! this thing is quiet (and huge ). I followed this flash video that you can get from the Zalman website. Hope that link works, I can't check it right now. Cheers, blizzard
DAW - ProArt B550-Creator / 5950X / 128GB / WD SN850 1TB / PT 2023.9 / RME UFX+ Macbook Pro Retina / 2.8GHZ / 512GB SSD / PT 2023.9 |
#4020
Hey Neatguys,
See my post above about the Zalman fan. No real problems here. I also had to remove some Artic Silver from my processor before mounting and I used some "isopropyl alcohol" and cotton swabs and it cleaned it up great. Just make sure it is completely dissolved before remounting. Cheers, blizzard
Pro Tools-qualified desktops outdated??? | robotboy | Windows | 4 | 05-28-2013 05:02 PM |
HP Desktops? | whatwhat | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 7 | 04-29-2009 09:33 AM |
HP Desktops in LE?? | finman29 | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 0 | 10-06-2008 11:06 AM |
Pro-Tools and RAM Drives. Laptops/Desktops - Possible? | epu | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 1 | 04-13-2008 09:34 PM |
HP Desktops | my cardboard box | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 1 | 04-05-2004 07:27 PM |
