Old 12-02-2010, 07:53 AM
alxt alxt is offline
Default Avid, 003/002 as Control Surface only! Please!
Avid,
what would it take to update the drivers or firmware to make the 003 or 002 usable as a control surface only while using a separate interface?
Is this feasible?
Thanks
Old 12-02-2010, 08:27 AM
albee1952 albee1952 is online now
Default Re: Avid, 003/002 as Control Surface only! Please!
You should spend more time here as there is already a nice long thread about this. Most of us think a firmware update could allow this and many have let Avid know our wishes already
Gigabyte X79/intel i7 3930K, 32GB RAM, Presonus Studio 1810C
I started in this business with nothing..........and I have most of it left
Old 12-27-2010, 05:42 PM
Avid,
any updates or comments on this issue?
Thanks
Old 12-27-2010, 06:03 PM
Barry Johns Barry Johns is offline
Avid I'll pay you $500 for this.
HD Native Pcie, PTHD 11, PT12 Vanilla, Omni, Lynx Aurora 16, 192 I/O (16 in/8 out), 24 Fader D-Command, lots of preamps and compressors.
MacPro 5.1 (12) Core (2009 MacPro 8 Core Upgraded to a 12 Core MacPro), 56 Gig Ram, SSD System & 3 - 2TB Drives, OSX 10.9.5, Windows 10 Via Bootcamp
Old 12-27-2010, 08:09 PM
HD2 HD2 is offline
The work around in the mean time would be to have both the 002/003 and your other interface hooked up. When tracking, launch PT's using the "other" interface and then switch to the 002/003 for editing and mixing.
OR if the other interface has an optical output, you could connect that to the optical in on the 002/003 and then you don't need to close and open your session. You get the best of both worlds.
Old 12-27-2010, 09:54 PM
Hotcrazyfruit Hotcrazyfruit is offline
first solution would work, 2nd solution would be limited to 48 khz
Core i7 920 OC'ed @ 4.0 GHz (200 X 20)
12 GB Patriot Viper Extreme
Asus P6T
OCZ Agility 64 GB SSD
Hitachi 1TB 32 MB HDD
WD Caviar Black 500GB
Saphhire HD 5850
3 x 20" monitors
Eleven Rack w/ ERXP
Fender Super Champ XD
Marshall JCM2000 DSL100 Silver Edition W/ Silver Jubilee Cabinet
Old 12-27-2010, 10:30 PM
asmarti08 asmarti08 is offline
Why would you be limited to 48kHz doing that? Is that a limitation of using optical?
Pro Tools 9 w/ Focusrite Saffire Pro 40, Presonus Digimax, and two Ward Beck pres
- 2012 Macbook Pro
- Windows 7 Professional (64-bit)
2.83 GHz Intel Core2Quad Q9550 // 8GB DDR2 800 RAM
Old 12-27-2010, 10:38 PM
HD2 HD2 is offline
Yes, being that there is only one port.
Old 12-27-2010, 10:40 PM
So if there were two ports going in, it would split the signal to accommodate a higher sample rate?
- 2012 Macbook Pro
Old 12-27-2010, 10:47 PM
HD2 HD2 is offline
Well actually I think it is not so much the one port but more about whether it supports SMUX which i don't think it does. If it did you could do 96k but only four channels. Do a search for SMUX on the forum and do some reading if you want to know more.
[IMG] code is Off
003 control surface (As audio) & control 24 as surface crizdee ProControl, Control|24, Command|8 7 01-04-2016 12:30 PM
Avid S3 control surface jacko Artist Series 1 03-07-2014 06:44 AM
Control Surface For Protools 10 Mackie Pro Control or Avid Artist Control lberrios1962 Pro Tools 10 18 05-26-2012 12:51 AM
D-Control Es32 Control Surface No Sound from Headphone outputs mark007 Pro Tools TDM Systems (Mac) 0 02-08-2012 07:03 PM
Mackie Control Universal or Tascam 1082 for control surface? anders Pro Tools TDM Systems (Mac) 5 05-28-2007 06:12 AM
