#41
Re: Warning! Don't sync your ilok account
Thanks, JC |
#42
-JC |
#43
Getting off topic here (we should move this to the Heartbleed thread) but you are stating that ilok.com was unsafe, though the info you posted clearly says "unsure" and "unclear" so to set the record straight... ilok.com is not vulnerable to Heartbleed.
iLok posted info here and Avid has published a Heartbleed FAQ here. -JC |
#44
I just ran into something frightening. EW (aka Soundsonline) who make all kinds of orchestral libraries for the Play engine deleted a thread I started where I mentioned about the iLok issue people are running into here and to be careful if you decide to sync your iLok. The reason they gave me was they didn't want to frighten their customers, that EW doesn't allow resales of libraries, and that they (EW) would be the ones to tell people if there was a problem.
Apparently they didn't bother to read the two threads from here I linked to that show it's not only resold licenses but initial purchases that are being deleted from people's iLoks. I wrote back to them and will be waiting to see what kind of response I get back. edit for update: Just heard back from admins at EW and the reason they gave me for deleting the post was that it was considered 'industry sensitive' and they don't allow criticism of companies they work with. I never criticized iLok or anyone else - just tried to make the community aware over there of these issues. Last edited by musicman691; 04-18-2014 at 10:35 AM. Reason: heard back from EW on thread deletion |
#45
The report says "Possibly Unsafe" and "Assessment: It's not clear if it was vulnerable..." because the test at lastpass.com can't really tell. They may not be checking for an actual vulnerability, but may be just trying to check the version of OpenSSL. We have additional security on top of it, so they aren't able to even see the version - hence the "It's not clear..." assessment. Our sites and services use a version of OpenSSL from the 0.9.8 branch, which was never vulnerable. If you'd like to check sites you use with a more robust test that actually looks for the vulnerability, you can try https://filippo.io/Heartbleed So, since our user facing services have never used a vulnerable OpenSSL version, we have never been vulnerable. The test at https://filippo.io/Heartbleed proves this by attempting the vulnerability and failing. I hope this helps. |
#46
Shouldn't "taking action against them" also include reparations for the victims of their fraud?
iMac Pro - MacOS 10.14.6 --- - Pro Tools U HDN 2019.6 - Avid HD Omni + HD I/O 8x8x8 - C|24 | S3 | Dock |
#47
JC, Thank you so much for the help, and so quickly. I have solved the problem and I think it may have been user error. What are the chances that my 'TLC' option expired around the same time as this issue? I'm thinking that was the issue. Did a sync/repair and refresh on my 'TLC' and now all is well here in FBRrecording land! Going to set myself a reminder to refresh my 'TLC' every 90days. So impressed with your response to this matter. Thank you again. Wes
FBR recording - https://www.facebook.com/fromthebase...cordsrecording @FBRrecording - Instagram Rig MBP 15" High Sierra 10.13.3, i7 2.6Ghz, 8Gb DDR, 750Gb 7200rpm, PT 2019.5, Focusrite Saffire Pro 40, Octopre MkII, Glyph GPT50, Avalon 737sp, AMS Neve 1073's, API 512c, CAPI 312's, DW drums, Fender Guitars/Amps, AKG, Rode, Sennheiser, Neumann U87 & KM184's, Coles 4038, Equator D5 monitors |
#48
I was thinking the same thing - but I'm sure pace has a button that makes u sync regardless if how much time you have left on your sync for TLC
#49
They may, but I try to refrain from running the iLok manager unless I have an issue. So I'm unsure how often it may make you try to run the sync. What made me think it was the TLC was that I remembered that a few months ago...LOL probably 3, I had the same issue. Once I reviewed the TLC data you see that they indicate that if you do not sync and 'refresh' your TLC then after 90 days, then your iLok will stop working as if it was stolen or lost.
#50
At this point I have to say, it's irresponsible to rely on Ilok for anything. I have my old TDM system with a functional Ilok key that I will *never* touch again, *never* sync, nothing of the sort, and I will CERTAINLY not buy any software license that is held hostage to the whims of this hack company. This kind of incompetence would result in immediate firing of your ass in just about any business except maybe fast food.
Cannot remove my iLok from an account with iLok License Manager | roberts | macOS | 6 | 06-10-2013 02:28 PM |
New iLok from Digital Village is already registered to another iLok.com account!? | Vytis | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 5 | 02-06-2009 01:09 AM |
can I re-register older ilok into new ilok account? | drguitar | Pro Tools TDM Systems (Mac) | 3 | 10-18-2008 11:04 AM |
iLok License not found (TL) - visible on iLok.com account | LiamSlack | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 2 | 03-17-2008 11:02 AM |
Registering Mpowered ILOK to ilok account? | Matt Whritenour | Pro Tools M-Powered (Win) | 1 | 03-22-2006 07:17 PM |
