Old 03-09-2013, 02:34 PM
alidav alidav is offline
Default protools 10 clip gain line /volume line
what is the real difference between working on clip gain line and volume line?
Old 03-09-2013, 02:44 PM
Stig Eliassen's Avatar
Default Re: protools 10 clip gain line /volume line
Clip gain takes place before the inserts, track volume takes place after the inserts. The exception is the master fader, where the inserts are post-fader.
Old 03-09-2013, 03:35 PM
I have created a project with omf files coming from a short movie sequence of FC7,
In volume Automatiom i see a lot of volume change, but of course ill employ several plug in, what is therefore your general suggestion about managing this material? Pt offer the choice to not import volume, fades etc.
Old 03-09-2013, 05:21 PM
Sounds like the movie has a rough mix going, and I would take a listen to it as is. I haven't done many video/movie projects, but I always listen to what they've done to the audio, and then I start over.
Move automation and clip based line around. yamahadrums Pro Tools 10 2 09-27-2012 01:29 AM
Clip Gain Line on D-Command? Borgbilly ICON & C|24 5 09-13-2012 09:43 AM
Clip Gain and volume autiomation bonzerboy Pro Tools 10 3 05-07-2012 11:52 AM
Clip-gain post-EQ but pre-volume-graph? Frank Kruse Post - Surround - Video 11 11-29-2011 10:18 AM
Converting Volume Automation to Clip Gain = Higher Volume! EricWillhelm Pro Tools 10 8 11-01-2011 11:12 AM
