Old 02-12-2009, 11:16 PM
midnightsun midnightsun is offline
Default Running out of steam
I don't get it. PTLE 8 as working great on my MBP 2.4Hz ith 4 GB RAM with a MBox Mini. Now I keep freezing up and getting messages saying to increase the H/W buffer size which I have done to the max. Things work for a while then I get another freeze and a message to increase CPU usage which I do for only temporary benefit. No matter what I do my system keeps freezing up and I get messages to increase the H/W buffer.
I have never had this problem with my PTHD system on a G5.
Old 02-13-2009, 01:01 AM
TOM@METRO's Avatar
Default Re: Running out of steam
Are you recording audio onto a separate drive?
Are all plugins up to date and qualified?
Are you running any unnecessary background services?
~ tom thomas
Formerly hobotom
HD Omni and 192 I/Os
Windows 10
Intel Hexcore i7
All Samsung Pro SSDs
Ampex MM1200 2" 24 trk tape
www.metrostudios.com
Old 02-13-2009, 04:54 AM
Mikeren Mikeren is offline
Does the MBP shows an DAE option for 1 or 2 RTAS processors (my dual does--assume core duo does too)?
If it does make sure its set to 1 processor. The setting could have been changed. Happened to me, with similar symptoms.
MR
Learn to listen. Listen to learn.
Old 02-16-2009, 10:27 PM
I am not using a separate hard drive and I am only using the plugins that came with PT 8
Old 02-16-2009, 10:28 PM
MR
I will give that a try. Thanks.
Old 02-17-2009, 08:24 AM
Default Problem solved
Mikeren.... you hit the nail on the head. My DAE option was set on 2 processors for RTAS and I changed it over to 1 processor and no more freezes or crashes.
I am curious why the RTAS can's use more than one processor.... oh, well.... back to making music.
Many thanks to all.
MR
Old 02-17-2009, 08:36 AM
The Dougfather The Dougfather is offline
Default Re: Problem solved
You should only need to this if you have non Pro Tools optimized plugins, i wouldn't expect any of the digi plugins to come under this banner, definitely no third party plugins?
iMac i5 2.8GHz, Macbook Pro 2.4GHz, Pro Tools 10/11, MOTU 828mk2, Presonus Digimax FS, Presonus Firestudio Project, TC Konnekt 24D
iCON Photography
Old 02-17-2009, 10:37 AM
peppertree peppertree is offline
One problem is that some idiot left Elastic audio enabled by default when you install pro tools 8. This means every new track you create gets Elastic audio put on it for who knows what reason. Go to the preferences dialog and disable that...it's poison...
Need to blow some steam,please understand DHG MUSIC Aspera DigiDelivery 4 05-24-2012 05:40 PM
Dual Boot 10.6 running 8HD & 10.7 running 10HD STL Audio macOS 3 04-14-2012 05:38 AM
OT: Need GREAT / Specific Steam Train Sample KingFish General Discussion 7 09-30-2011 10:53 AM
xPost: Need GREAT / Specific Steam Train Sample KingFish Post - Surround - Video 2 09-28-2011 11:56 PM
PT HD9 (running native with motu) running out of memory syMPh Pro Tools TDM Systems (Mac) 1 11-21-2010 07:34 PM
