Old 05-10-2010, 11:32 AM
krishkrasj krishkrasj is offline
Question parametric output EQ
Hello, I'm doing my first gig with d-show this weekend, and I need some help. I want parametric EQs for my outputs but I cant find the EQIII from the insert list. I reckon it is installed with the D-show software, so it should be there, right?
Is there any way you can enable parametric EQs for the outputs without inserting plugins? digidesign sure most have seen the need for something else then graphic EQs?
Thanks in advance,
christoffer
Old 05-10-2010, 12:48 PM
Mike Z's Avatar
Mike Z Mike Z is offline
Default Re: parametric output EQ
yes, a parametric EQ on the output would require a plug-in. you can find the stereo version of EQ III here:
http://www3.digidesign.com/index.cfm...wnloadid=44873
hope this helps,
-Mike
Avid Live Sound Support
MDW Hi-Res Parametric EQ Demo MatthieuH RTAS & TDM Plug-ins 6 12-05-2013 04:54 PM
MDW Hi-Res Parametric EQ v5 is now available Avid Technical Alerts 1 08-24-2012 12:55 PM
Help needed about Parametric EQ on 11R Alp Eleven Rack 24 08-15-2011 06:07 PM
Parametric EQ Settings brianiac5150 Eleven Rack 0 03-23-2011 07:27 AM
What is Q in a parametric? dummy20707 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 3 02-22-2002 08:03 PM
