Go Back   Avid Pro Audio Community > Pro Tools Software > Pro Tools 2019
Old 07-28-2019, 06:24 AM
pm mastering studio's Avatar
pm mastering studio pm mastering studio is offline
Default Avid Midi I/O drivers for Max OS Mojave and PT 2019.6 Ultimate
Hi there,
I just installed Mojave to work with my PT2019.6 Ultimate but now i find the Midi I/O isn't recognised anymore and the plugin is moved to the unsupported folder.
what can I do to make it work again ?
thanx for your input
Philippe Meiresonne
(Belgium)
http://www.pm-mastering-studio.com
SYSTEM HDX MAC
ProTools Ultimate 2019.12 | 1xHDX Card | MacPro 6 Core 32GB Ram PCIe 512GB TrashCan|Magma Thunderbold EB3T|2x PRE | 96 | 192 I/O | HD I/0 16/16
Midi I/O | D-Command ES +16 fader Pack | Xmon | Eleven Rack
SYSTEM 02
Mac OS 10.15.0 |MacBook Pro | 16GB RAM | ProTools 2019.10 | Rack003+ Factory
SYSTEM 03
Windows 10 |32GB RAM | ProTools 2019.12 | Focusrite Scarlet 8i6 AVID S1+DOCK
Old 07-28-2019, 06:32 AM
JFreak's Avatar
JFreak JFreak is online now
Default Re: Avid Midi I/O drivers for Max OS Mojave and PT 2019.6 Ultimate
MIDI I/O end of support date is 2012
Janne
Old 07-28-2019, 08:45 AM
so I 'll have to throw a good Midi controler away . Damn
Philippe Meiresonne
(Belgium)
SYSTEM HDX MAC
SYSTEM 02
SYSTEM 03
Old 07-28-2019, 09:06 AM
ChuckS ChuckS is offline
What OS version are you coming from? If the driver is a kext file it may have something to do with unsigned extensions. Search on Mac OS user approved kernel extensions.
PT 2019.10 DP 10.01 VEP 7.x Komplete Audio6 HP Envy 8G i7 Quad Laptop Win10 (x64 1909)
PT 2019.10 DP 10.01 VEP 7.x 828mkII ADA8200 MTP-AV 2011 Mac Mini i7 Quad High Sierra.6
Old 07-29-2019, 01:34 AM
WorldStudios WorldStudios is offline
I use it exactly like you want to. When you try to install the extension you get an error message that the driver is not right for Mohave, but you simply have to go to system extensions Privacy and allow it to install. This is true for quite a few installers, like the Integra 7 driver for instance. You will get a warning at some point later on when booting up that the driver will not be supported in future versions of Mac OS but you just ignore/accept that.
Johan Bejerholm
World Studios
Sweden
Phone +46707773443
Old 07-29-2019, 07:02 AM
Also, a word of caution with any future OS releases. Mojave is last OS level to support 32 bit. Just guessing, but good possibility that the MIDI I/O drivers are 32 bit, so you might want to investigate. There would be no user approved/privacy options that would fix that.
Old 07-29-2019, 01:53 PM
Eric Lambert's Avatar
You're correct. They are 32-bit, and they will absolutely not work with OS Catalina. I'm honestly surprised that they're operating under Mojave -- I believe we had to ditch our Avid MIDI I/Os a couple years ago but could be wrong.
Old 07-30-2019, 12:20 AM
Like I said, it still works. I use it mainly to send Sysex messages to my Bricasti and the occasional notes and patch data to my fs1r. I bought a smaller interface with modern drivers to do that some years ago but it stopped working after a
few years and then, in panic, I tried the MIDI IO and it still worked - and has kept on working. Now under Mojave.
Johan Bejerholm
World Studios
Sweden
Phone +46707773443
Old 07-30-2019, 11:58 AM
Awesome!
2019 iMac i9 + PT 2018 + Mojave rwbreck General Discussion 41 11-22-2019 02:13 PM
GUI issues - 2019.5 and Mojave BrandonUnis Pro Tools 2019 12 06-21-2019 09:42 PM
Mojave Thinks PT 2019.5 is a 32-bit App moogboy100 Pro Tools 2019 3 05-28-2019 10:44 AM
PT 2019 Mojave macPro 5,1 off the wall Pro Tools 2019 20 05-13-2019 07:00 PM
new SSD for PT 2019 and Mojave question. Anibal Pro Tools 2018 0 05-09-2019 10:14 AM
