Old 07-26-2004, 10:16 PM
starvinboi starvinboi is offline
Default 002 will not record midi notes sent from my mpc?
I went through step by step reading the 002 (manual/protools guide book) and performed all of the input/output midi settings required to record the midi/drum notes sent from my mpc2000xl into the protools 002 mixing console. I can hear the drum notes in my headphones connected to the 002 mixing board as I play them from the mpc, but the notes don't register on the midi track when I hit record.
Can someone please give me some suggestions on what may be the cause of this?
Old 05-05-2005, 01:33 AM
mobonix mobonix is offline
Default Re: 002 will not record midi notes sent from my mp
I am having the same problem. I have both my Motif and MPC sync'd up properly using Midi but the MPC will not record any notes, nor do I see any levels on the velocity meter. 002 console has "midi in" led lit.
I have an audio track and a midi track both armed for recording. Only audio is recorded during the sync. My pro tools triggers the MPC.
How do I record the notes into the editor?
Old 05-05-2005, 08:55 AM
cetanorak cetanorak is offline
I have not had access to my Pro Tools gear for about a month now, but these would be my suggestions off the top of my head.
Make sure the input to the MIDI channel is set to "ALL", I think.
Try turning Low Latency Monitoring off, and see what that does.
Of course, make sure to record enable the MIDI track.
Old 05-05-2005, 10:32 AM
Input to MIDI is set to ALL,
Low latency monitoring is not a factor,
and MIDI track is record armed.
None of those things work. I know the MIDI devices are set up correctly because I am able to sync. I've played with different options with midi beat clock and trying different channels. Nothing works
Old 05-05-2005, 10:37 AM
DigiTechSupt's Avatar
In the MIDI menu, make sure that 'MIDI Thru' is enabled.
This should solve the problem.
Avid Audio Tech Support
Support FAQ
Old 05-05-2005, 01:50 PM
Thanks for everyone's help!
I finally got it to start recording MIDI notes sent from the MPC.
MIDI Notes Record Short.... goosefreak Pro Tools M-Powered (Mac) 3 02-07-2012 07:36 PM
Recording Midi notes and keeping existing notes during record Sherbert99 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 3 09-15-2008 10:40 AM
PT doesn't record MIDI notes anymore Studio Studio MIDI 3 02-12-2008 07:07 AM
Record MIDI track Then Record Again To Add Aditional Notes + JCWarrior Tips & Tricks 5 04-13-2007 04:51 AM
Midi: can't record midi notes synth input myrios Digidesign Hardware & Software 1 10-03-2002 11:59 PM
