Old 10-03-2008, 10:57 AM
CD Productions CD Productions is offline
Default PCI HD Accel cards, Magma pci chassis and newer PCIe Macs
I currently have a PCI HD3 Accel system with a Magma Expansion chassis and a G5 dual 2gig power PC. If I want to upgrade my Mac, do I have to cross grade my cards and chassis as well?
Charles Dayton, CAS
Twisted Avocado Post Audio
http://www.imdb.com/name/nm0206743/
Old 10-03-2008, 04:52 PM
Craig F Craig F is offline
Default Re: PCI HD Accel cards, Magma pci chassis and newer PCIe Macs
you could only get the PCIe host card from Magma and keep your chassis and cards (assuming it's a PRE64)
it would be your cheapest rout, you would probably be able to afford a 4th or 5th card to go into your chassis
PT11 System Requirements link http://avid.force.com/pkb/articles/C...m-Requirements
Thank you,
Craig
Old 10-03-2008, 07:32 PM
Thanks. I was hoping that was the case.
Charles Dayton, CAS
Old 10-04-2008, 02:38 AM
crizdee's Avatar
crizdee crizdee is offline
As you are currently running on PCI then i don't think you would currently be using a Magma PE6R4 as this is a PCIe only chassis.
A PE6R4 is definitely the was to go as it is the fastest Magma have made and is latency free!!
What chassis are you currently using?
Chris
Producer, Engineer,
Slow Readers Club_Build A Tower top 20 UK album charts
www.ukmastering.com
PT10.3.10 Mountain Lion HD6 accel Magma PE6R4 Control 24 MacPro 12 Core 3.46ghz UAD-2 Octo x2. Manley Vari-Mu, Manley Massive Passive, SSL VHD, ADL600, Grove Tubes ViPre, Tube-Tech CL-1B. Hafler TRM active monitoring.
Old 10-04-2008, 05:05 AM
Delta Music Belgium's Avatar
Delta Music Belgium Delta Music Belgium is offline
I have a similar question, I have a Digidesign 7 slot 64 bit PCI Expansion chassis (is a copy of the Magma 64 bit chassis, just with Digidesign printed on it) with a HD 7 Accel in it, is it possible to get a PCIe host card for it?
Marc Schellekens
Delta Music Belgium - Pro Tools | HDX Studio
http://www.deltamusic.be
System 1: Mac Pro (Mid 2012) 3.33 GHz 6-core - 32 GB RAM - OS X 10.13.6 - Magma EB7 - PT HDX3 - PT Ultimate 2018.12 - HD I/O 16x16 - 192 I/O - 192D I/O (x3) - SYNC HD I/O - Apogee Big Ben - Rosetta 200 - Slate RAVEN MTi2 (x3)
System 2: Mac Pro (Mid 2010) 3.33 GHz 6-core - 32 GB RAM - OS X 10.9.5 - Magma PE6R4-I - PT HD 6 Accel PCI - PT HD 10.3.10 - 192D I/O - SYNC I/O
Old 10-05-2008, 10:08 PM
Zep Dude Zep Dude is offline
No, you have to get the new Magma chassis (around $2000) if you go to a PCIe based mac. No way around that. I just asked Magma since I'm thinking of going intel Mac.
Angelo Montrone
Majestic Music
Studio / Label: www.majesticmusic.com
Old 10-06-2008, 09:02 AM
ejsongs ejsongs is offline
magma is very confusing on this issue. i called them once to ask the same question as i have a p7r4 chassis. turns out that i can run this as a 64 bit instead of 32bit and can get a pcie host card for it yet they told me that i would have to upgrade the guts of my chassis or get a new one.
it makes no sense as their website contradicts their tech support. i'm going to get a pci e host crad and just try it when i am ready to make jump.
ej
Old 10-06-2008, 09:43 AM
ej
That's exactly why I added the question to this thread...
Marc Schellekens
Old 10-07-2008, 08:03 AM
i think the digi chassis or the magma 7 slot 64 bit chassis wont work as there is no pci e host card offered.
http://www.magma.com/products/pci/7PCI/prices.html
gutting you chassis is slightly cheaper that buying a new one.
hope this helps!
ej
Anyone running Accel cards in Thunderbolt to PCIe chassis? digidesigner Pro Tools TDM Systems (Mac) 20 03-02-2014 04:03 PM
Newer Mac for old HD2 Accel PCI cards? PCI fits PCIx? magnetic7 Pro Tools TDM Systems (Mac) 5 01-30-2008 09:50 AM
Magma PE64R Chassis or upgrade PCI cards to PCIe crizdee Pro Tools TDM Systems (Mac) 9 01-27-2008 02:22 AM
New Magma PCIe to PCI Chassis www.Silentservice.de Pro Tools TDM Systems (Mac) 2 05-05-2006 11:44 PM
Magma Chassis for HD2 Accel Imagine Pro Tools TDM Systems (Mac) 6 07-11-2004 08:02 PM
