Old 05-16-2013, 07:27 AM
DESVED DESVED is offline
Default Impossible to start Pro Tools on MacPro after downgrade Mountain Lion back to LION
Well ... trying to upgrade to mountain Lion on my Mac Pro 2009 even if the Apple specs said it was ok ... it didn't .. so I reinstalled Lion ... nothing wrong so far ...
Before upgrading ... My Pro Tools 10 was working fine 10.3. ...
since the downgrade I tried like 10 times to reinstall Pro Tools ... even went down to 10.2 ... but impossible to open PT anymore ...
the moment I open the program it shuts off instantly ... in less then 2 sec ...
I already uninstalled 10 times ( standard and extended uninstall) reinstalled ... but i always end up at no start at all ...
I even threw away all Avid related files in libraries ... etc ... still nothing ...
it probably had something to do with the trouble trying to upgrade to Mountain Lion ... but the downgrade to Lion works all good on any other program ...
so Im a bit blocked in options after 3 days of trying ... anyone have a tip ??
Thank You for your time.
Old 05-17-2013, 12:06 AM
crizdee's Avatar
crizdee crizdee is offline
Default Re: Impossible to start Pro Tools on MacPro after downgrade Mountain Lion back to LIO
When you reinstalled Lion did you wipe the drive and do a totally fresh install?
What version on lion have you updated to? And did you use the "combo" updater
Have you installed the ilok driver?
Is the ilok plugged in yep I've seen that one before!
What interface? Or using built in audio?
A fresh install of lion and fresh install of PT along with the ilok driver and the interface driver if using one and it should be working fine.
Chris
Producer, Engineer,
Slow Readers Club_Build A Tower top 20 UK album charts
www.ukmastering.com
PT10.3.10 Mountain Lion HD6 accel Magma PE6R4 Control 24 MacPro 12 Core 3.46ghz UAD-2 Octo x2. Manley Vari-Mu, Manley Massive Passive, SSL VHD, ADL600, Grove Tubes ViPre, Tube-Tech CL-1B. Hafler TRM active monitoring.
Old 05-21-2013, 03:18 PM
DetroitT's Avatar
DetroitT DetroitT is offline
Boot in Lion recover, Verify disk (Repair if errors) then Repair permissions.
Restart.
Clean uninstall of Pro Tools.
If not at 10.7.5 use combo updater to get there.
Install PT's HD 10.3.5
Restart.
Pro Tools will Likely will crash on first try (Registration).
Install latest iLok drivers.
Log out / in
Launch Pro Tools again holding the "n" key which will open playback engine.
Adjust CPU's less 1, Buffer start at 512, Disk cache....Choose HDX / HDN what ever you have.
Come back and let us know how you faired.
T
(Help us Help You)<<<click here
Testing:All APFS 90% 10% Audio on HFS+(Testing 1.5 yr in)
Pro Tools U-2019.6 MacOS 10.14.6
Second boot-10.13.6 (Avid HDX-1 Omni)
(MP 5,1 / 64-Gb)
(Sapphire RX-580 MacVCEdition, 3-Displays)
MOTU FW-CoreAudio (for poly recording)
(SSL-HUI-MIDI over IP)
music-design-creation
Post Music-Sound mixing, Production-Enhancements.
Audio Tuning and System Services
lion -> mountain lion question grant howarth macOS 3 05-01-2013 01:24 PM
Lion or Mountain Lion for mid-2009 MBP with PT9 miezurecords macOS 0 03-17-2013 12:38 AM
Would you go from Snow Leopard to Lion (not Mountain Lion) if you could? EricWillhelm macOS 9 01-11-2013 10:55 AM
Downgrade from Mountain Lion to Lion The golfer macOS 7 11-14-2012 05:53 AM
Pro Tools 8.0.5 Mountain Lion Mac 10.8 madballa Post - Surround - Video 1 09-30-2012 05:10 PM
