Plug & Mix Basspeg Crashing PT12.7 On Startup
Plug & Mix updated the VIP pack, which I have installed. Upon launching PT 12.7, it crashed and hung on the new Basspeg plugin. Attempted several more launches, always crashing in the same spot.
I moved Basspeg to the Unused folder and now PT launches just fine. Anyone else seeing this? I'm on Windows 10, PT 12.7 http://www.plugandmix.com/news/n40-P...he-VIP-Bundle/
Brian Windows 11 Pro | macOS 12 Pro Tools 2022 benonistudio.com Youtube Channel - benonistudio Plugin Deals @benonistudio |
Re: Plug & Mix Basspeg Crashing PT12.7 On Startup
Did you try with PM Chainer?
Dell XPS 8700. Intel Core i7-4770 CPU @ 3.40GHz. RAM: 16GB. Windows 10 Home x64. NVIDIA GeForce GTX 645. NI Komplete Audio 6. Pro Tools Software 2019 amagrasmusic.com |
Well, it crashes on startup of Pro Tools, so I can't even get to Chainer. But I will install the latest version of chainer and see.
Same here. I was excited to try it out last night, but I had to uninstall it right away.
Daniel Asus P6X58D-E, Intel i7 930, 12 Gb Corsair XMS3 DDR3 2 WD Black Cavier 640 Gb SATA 3Gb/s 32MB Cache Windows 10 Pro |
I only ask because Chainer loads all their plugins even if you don't have them in AAX. Maybe it is possible to use it that way until they come up with a fix.
Yeah, i'll give it a go and see if I can use it that way.
Confirmed then, good, it not just something with my system.
There's some issues with BassPeg it seems? Probably worth reporting your woes here.
http://forums.plugivery.com/index.ph...=315&start=315 That said I have been using it OK! Stephen
Mac mini M1 2020 16Gb Memory- 256Gb Storage, Monterey, Pro Tools 2022.9, Focusrite Scarlett 2i2 https://www.waves.com/r/djgsi6 |
i have the problem that the message comes up: "Clarisonix and Distorted are not valid 64 bit AAX plugins."
My ears! My ears! clausiii ----------------- MacBook Pro i7 Quad 2.6GHz 16GB RAM ProTools 2020.11 Avid S1 Avid Dock Avid Control Digidesign Command|8 macOS Catalina MOTU 4pre MOTU Track16 Axiom Pro 25 LinnStrument 128 Roli Seaboard Block tons of stomp boxes tube amps guitars noise |
That's a bugger!
I was looking forward to updating, and giving Basspeg a whirl. I'd definitely raise this issue on the previously linked bug report thread, on their forum. I've found them to be responsive, and pretty swift at fixing bugs that have effected me. That said, I detailed several significant bugs (on page 21 of the bugs thread), and there have been no updates until now. I hadn't laboured the issue, as there were various things going on at Don't Crack that were obviously going to put VIP updates on the back burner, and I just worked around most of the problems until I forgot about them. Would be interested to know if this new release (new bugs not withstanding) has addressed any of those previous issues I raised. Sent from my iPhone using Tapatalk |
PT First Crashing on Startup | SIU Telehealth | Pro Tools | Intro Discussion | 3 | 12-19-2016 08:25 AM |
Pt12.6.1 crashing | marcsprotools | Pro Tools 12 | 7 | 12-12-2016 04:59 PM |
PT12 crashes during startup when loading plugins | MikeV252 | Windows | 2 | 12-06-2015 07:01 PM |
pt 8 le mixer plug ins crashing program at startup | pounceinternational | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 26 | 12-31-2008 06:46 AM |
PT LE Crashing on Startup | beggehorn | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 6 | 05-18-2006 09:18 AM |
