HELP! M box 2 multiple errors with pro tools 10
Hi.
So I've been using Pro Tools and M-Audio Fast Track for past 2 years, and I recently changed my interface to M Box 2. The problem I have is whenever I plug in, the lights comes out, but whenever I play the track either it doesn't play the inst/track but makes tick sounds (it's not metronome.) or get error 6104 (Pro Tools Error (-6104), CPU usage is holding off USB audio). I researched and they said reduce/decrease the buffer size. I changed to 2 processors, 128 samples and it worked totally fine. BUT, when I started recording (vocals) for 10 minutes, I started to hear these distorted buzzing/cracking sounds while recording my vocal on a inst track then the another error message appears saying "problem detected with audio clock. check that your clock source and sample rate are correct". They are correct. So i plugged out the USB cable and put the ilok again and now pro tools won't show up although they are all plugged in unless I restart my macbook. I searched everything and solved things out step by step but it is keep going over and over with the same errors. I thought it is pro tools being ridiculous but when I use my old fast track, it works totally fine. Is it the problem with M Box 2 or did I not handle the programme well with pro tools? It will be really appreciated if you guys could help me out because I am really confused now.. Interface: M Box 2 Pro Tools Ver: 10.0.0 Macbook Pro 13 OS X Version 10.8.3 (12D78) Processor 2.9 GHz Interl Core i7 Memory 8 GB 1600 MHz DDR3 |
Multiple 6101 errors | scott bourgeois | Pro Tools M-Powered (Mac) | 2 | 04-03-2012 07:31 PM |
Help - multiple errors with PT7, PT8, 002 and MBOXPRO2 (XP) | Skip Regan | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 5 | 04-22-2010 02:56 PM |
Multiple errors PT7.4.2cs1 Leopard 10.5.4 | Wasaia | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 25 | 04-16-2009 09:33 AM |
Multiple errors/issues in PT LE 8 | Big Blue Barry | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 3 | 02-27-2009 08:42 AM |
G4 Bus Errors with Multiple Monitors | steve-o | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 1 | 02-08-2000 08:40 AM |
