Old 10-14-2012, 10:49 AM
Gregor B. Gregor B. is offline
Default Dolby Products TC issues
Dear All,
I'm having some very annoying TC issues with Dolby products and Audiofiles that were created in Pro Tools. This happens to me in Dolby Media Encoder as well as in Dolby Media Meter 2 (v2.1.25):
- I load bwav 5.1 tracks of finished film projects (in order to either create ac3s or check loudness)
- All of them have 09:58:00:00 as start-TC, which is my default session start. Third party bwav-readers confirm this start-TC
- Framerate is either 24 or 25 depending on the project
- Once I load these files in either Dolby standalone application, it suggests:
Specify Range From: 09:57:24:04 To xx:xx:xx:xx (This TC depends on the length of audio) and 29.97fps as framerate
Now, first I thought it just couldn't read neither TC nor framerate and suggested this wrong start-TC, then I realized it would do exactly this on every single project I load - always 09:59:24:04.
It's wrong by ~00:00:34:20
And worse: If I specify range e.g. 10:00:00:00 to 11:30:20:00 to either measure loudness or decode for dvd, it will still be wrong by that amount and start measuring or decoding at ~10:00:34:20!
Workarounds with using "seconds" or "samples" instead of framerates also haven't proven helpful. On the contrary, if I try to type "Specify Range From: 120 seconds" it will simply jump to some cryptic number like 35844.1333
Last but not least, if I measure loudness with DMM2 on a project and specify range as it suggests from 09:57:24:04 To xx:xx:xx:xx I can take a look at the graph and read the TC values of specific parts of the film and the curve by simply holding my mouse on it. If I specify my desired range (which won't translate correctly as stated earlier), TCs in the graph will always be 00:00:00. It does tell me the time of day though, when that specific part of the files was measured, which I really couldn't care less about
This puzzles me, considering it's version 2.1.25, so I figured it must be an error in my workflow since I haven't read anything about it online.
Anybody having these issues?
Thanks in advance.
Gregor
HTML code is On
Dolby Media Producer Suite vs. Dolby LM100 TylerJohnson Post - Surround - Video 4 06-04-2012 02:41 PM
Dolby E and Dolby Media Meter Newbie Questions AudioPostChris Post - Surround - Video 4 02-08-2009 03:53 PM
Sync Issues With New Akai Products famousbeats MIDI 1 06-09-2008 05:46 PM
Any Issues With Recording Dolby E Into PT? Johnny2Laps Post - Surround - Video 7 08-17-2007 08:18 AM
Dolby Digital issues Mark Wheaton Post - Surround - Video 31 07-06-2003 02:06 PM
