Old 06-07-2012, 04:29 AM
Armando Armando is offline
Default Need help-plug-in deactivating/deactivating issue
Hello,
I've done searches on this issue but haven't found any concrete resolution to the issue. I'm running Pro Tools HD 7.4.2 on Mac OS 10.5.8 on a Dual 2.0 G5 with HD Core, HD Accel, HD Process, HD Process PCI all in a Magma 7-slot P7R464 chassis.
This is happening in a big session(over 40 tracks). The song's length is over 10 minutes. I've got the latest ilok drivers and the plug-ins are varied(Digi, Waves Platinum vs 7, McDSP, Sonnox Inflator, etc..)
Any assistance is greatly appreciated! Thanks!!
Armando
Old 06-07-2012, 09:07 AM
phatbeatstudio phatbeatstudio is offline
Default Re: Need help-plug-in deactivating/deactivating issue
Just because you have voices left doesn't mean there is any room left on the chips. Have you tried checking your system usage to make sure you have any chips left to work with.
It is very possible to run out of chips before you run out of voices.
Will the same thing happen if you use a RTAS plug in.
Old 06-07-2012, 09:49 AM
I have an entire Process card of available chips not being used.
Armando
Old 06-12-2012, 12:56 PM
kptkarl kptkarl is offline
Some plugins require a Accel card.
Old 06-12-2012, 01:19 PM
Got an Accel
Armando
Deactivating / Re-activating PT 10/11 Danny Pro Tools 10 4 06-16-2013 07:42 PM
7.3.1 Bug Deactivating Tracks mhmh Pro Tools TDM Systems (Mac) 0 02-02-2007 07:12 AM
Deactivating Automation... iamnerdyrocker Pro Tools TDM Systems (Mac) 5 01-29-2007 09:52 AM
Problem with Waves Plug-In's after deactivating/re Willya Pro Tools TDM Systems (Mac) 2 07-25-2006 11:56 PM
Deactivating Plug-ins ??? Dutchmuzik Pro Tools TDM Systems (Mac) 2 04-05-2002 02:00 PM
