Go Back   Avid Pro Audio Community > Pro Tools Software > Pro Tools 2019
Old 05-27-2020, 12:13 AM
Boe Larsen Boe Larsen is offline
Default AAE -9171 error
Hi Duc
It's been a while.
I keep getting these AAE -9171 errors. Once or twice a day.
My rig has been doing this as long as i remember - through different PT- and OS updates.
My buffersize is 1024.
I'm running PT 2019.12.0 / OS 10.13.6
Any ideas?
/Boe
Boe Larsen
Producer
www.millfactory.dk
Old 05-27-2020, 01:00 AM
Default Re: AAE -9171 error
Same answer as always, .... always suspect plugins... and do all the standard plugin troubleshooting steps, discussed on DUC many many times.
Old 05-27-2020, 01:08 AM
Yep, I know, but when you have 20 years of plugins, that might take a week or two
The thing is also that it's been happening across PT and OS updates...
Boe Larsen
Producer
www.millfactory.dk
Old 05-27-2020, 10:45 AM
So its more likely a plugin... that you have had across those upgrades. There is no silver bullet or guess that anybody else here can make. With current improved state over past 12.x releases you at least are in a much better state for finding a plugin is the cause and it not being broken Pro Tools.
Trash prefs, check it is not a corrupted session/set of sessions, make sure you are not doing insane long plugin/bus chains, do normal .aaxplugin file removal tests.... you should be able to confirm it’s a plugin within hours of testing... you might not get the exact plugin but in suitable batches... You can get close if the error happens frequently enough (maybe decrease buffer size to see if that helps with testing By having more frequent errors, and do not enable ignore errors) suspect mostly the plugins being instantiated in failing sessions...then trying all of they are not the culprit. And starting with confirming that removing all third party plugins gives you a stable system.
Old 05-27-2020, 10:27 PM
Thanks Darryl for taking the time to advice. Appreciated.
Boe Larsen
Producer
www.millfactory.dk
Repeated Error AAE-9171 JingleDjango Pro Tools 12 6 12-13-2016 11:52 AM
12.5 bug report AAE error -9171 solarduan Pro Tools 12 10 11-21-2016 09:29 AM
9171 error with HDX but not with Aggregate I/O pklein Pro Tools 12 0 07-15-2016 07:57 PM
PT 11.2 with HDX 9171 error David Sandwisch Windows 5 12-02-2014 07:24 PM
Scroll edit window causes -9171 error? Tim R. macOS 2 09-10-2013 07:33 AM
