Old 07-14-2016, 04:20 PM
john1192 john1192 is offline
Default Possible Issue .. after BTD .. need to Reset Playback Engine ..
"Possible Issue .. after BTD .. need to Reset Playback Engine .." .. so today, i bounced an MP3 and when i went back into the session after checking the MP3 on harddrive i had to reset my Playback Engine to get Audio back !!
just loaded up 12.5.2 last week ... small session .. anyone seen this ??
thank you john
Mac Pro 6-core 3.33ghz (2012) 24gb ram 256gb SSD -OS 10.12.6 for PT 11.3.2 & 2019.6 last version
Logic Pro X latest version
RME BabyFace Pro
Macbook Pro july 2014 2.5ghz 16gb ram 512gb SSD - OS10.14.6 - PT 2019.6 Ended here ..
RME BabyFace Pro
Old 07-17-2016, 08:13 AM
Alarry0829 Alarry0829 is offline
Default Re: Possible Issue .. after BTD .. need to Reset Playback Engine ..
My problem is when I launch pro tools 12.5.2 It sometimes slows down the tempo of my song. I then have to restart pro tools or shut down my computer for a minute and the tempo comes back. Also, on bouncing or export tracks or song, it slow down the tempo after bounce or export.
Old 07-18-2016, 07:58 AM
are you saying the actual Tempo is changing or are the Tempo #'s staying the same and the Audio is slowing down ??
RME BabyFace Pro
RME BabyFace Pro
Old 07-18-2016, 08:17 AM
midi sordino midi sordino is offline
thank you john
Is it an offline or online bounce that is causing the problems..?
I've been having issues with PT 12.5.2 sometimes not responding after an offline bounce (beach ball of death and have to force quit)
I've been on to Tech support and we're working through it. I've done all the recommended troubleshooting tips, optimised my system and taken my audio interface and peripherals out of the equation, and the problem can still occur, but it's intermittent.
At the moment it looks like it might have something to do with Logic Pro X (10.2.2) as it only happens after I've been using LPX on the MacBook Pro (Mid 2015, OS 10.10.5, Full Spec).
I see you use Logic Pro 9. Do you notice the problem occurring after using it?
Old 07-18-2016, 08:19 AM
offline ... i will check online .. and logic is on a separate partition ..
i just opened PT and no audio interface .. have to reset in playback engine again ..
then it comes back (pro tools) with the staticy sounding audio ..
i was booted into a test partition of 10.12 ... so it could be something to that ... once the NOn-Beta version is out i can do some better troubleshooting ..
and ... another strange thing is that even though PT was closed before a Computer restart .. pro tools opens when i come back ... weird ..
RME BabyFace Pro
RME BabyFace Pro
Playback Engine Issue (Won’t load session with chosen playback engine) MattyJones Pro Tools 11 0 11-02-2015 11:52 AM
Playback Engine issue lillo9546 macOS 4 03-03-2015 12:48 PM
Playback engine issue... TheEdster75 Pro Tools 11 2 07-15-2014 10:59 PM
Playback engine issue Bill Simmons Getting Started 6 07-01-2013 06:20 AM
Playback Engine>Current Engine issue Hunterkiss macOS 0 06-28-2013 01:14 PM
