Grid Value shortcut not working
Hi folks,
ctrl option +/- does not want to change the grid value. alt option +/- is working fine for nudge value. Can anyone help?? |
Re: Grid Value shortcut not working
I usually just Option-click the desktop in the lower left corner of the screen to switch to Finder. When I go back to PT, the shortcuts are back. For me, it's often Option-A that stops working.
Thanks for your reply but that hasn't solved it unfortunately
I see. Actually, it came out wrong before. Option-click to reveal Finder, then click somewhere on the desktop, and then switch back to PT.
In case you have the midi edit "piano roll" window open, make sure you have the window that you want "active". The active section will have a yellow outline around the controls at the top. If the midi portion of the window is active, those grid and nudge value indicators in the normal part of the edit window won't respond.
midi editor window not open so that isn't it
nudge value shortcut does work as well. have even tried a different keyboard with the same result |
Shortcuts seem to get lost when there is a plugin open, like RX through audiosuite.
Command Tab, then command tab again will switch between apps, and its back. Most the time you can see the a-z on the region window is not yellow. |
Command-tab works, but yesterday my producer lost tab to transient - there was a Waves plug open. I came over and hit 'esc' then all the little shortcuts worked again :)
... but does it help the chorus? |
Thanks for all the suggestions folks (and sorry for the slow response)
No luck with any of them unfortunately, looks like it might have to be a re-install... |
Shortcut to change grid value? | bad jitter | Pro Tools TDM Systems (Mac) | 6 | 05-27-2020 11:09 AM |
Keyboard shortcut to highlight until next grid | the hecksome | Pro Tools 10 | 1 | 11-08-2012 09:19 AM |
Regions/Markers grid shortcut? | ajs | Tips & Tricks | 1 | 10-22-2004 02:45 AM |
seperating regions to grid shortcut? | pasty | Tips & Tricks | 2 | 03-14-2004 01:16 PM |
Shortcut between grid and sample | JLEpperson | Pro Tools TDM Systems (Mac) | 1 | 09-13-2001 11:22 AM |
