Old 05-22-2007, 11:12 PM
stern stern is offline
Default Play/Edit Marker stopped follow timeline selection
If anyone can help me with this one, I would be very grateful.
In the middle of editing a session, suddenly the play/start marker no longer follows my timeline selection. I have the corresponding box checked in the "Operation" preferences (as it was previously as well), but it makes no difference. The symptoms are the following. It doesn't matter where I place the cursor. Playback begins at another place (the place where the cursor was when the behavior began). Interestingly enough, after I stop playback, the cursor blinks at the place where I was trying to place it. But playback is always at the other location. The only way I have found to move the playback point is to use the |<, <<, >>, and >>| transport buttons.
I assume that while editing, I hit some key sequence that either put PT in some different mode that I haven't noticed or changed some preference that I can't locate. I have tried exiting and restarting ProTools, creating a new session and importing my session data and tracks over to the new session, etc, in the hopes that I can create a session that behaves the way it was behaving prior to a half hour ago, but no luck. It seems to be a setting that has changed for PT as a whole instead of the one session.
Any help is greatly appreciated as I can't make any progress on the session in its current state.
Thanks.
Old 05-22-2007, 11:30 PM
Default Re: Play/Edit Marker stopped follow timeline selection
Trash the Prefs and reboot. Then reconfigure the Preferences to see if the problem still persists.
filosofem
Aaron Mulqueen - 001 HD Native
Play Start Marker Follows Timeline Selection - no effect in 10.3? Richard901 Pro Tools 10 32 02-02-2015 07:35 AM
Grr.. Link Timeline Edit Track Edit Timeline Selection confusion deepfrequencies macOS 3 02-06-2014 02:40 PM
Play does not follow edit marker elliothunt 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 1 06-16-2009 05:50 AM
TIMELINE SELECTION MARKER??? craigdwlr Pro Tools M-Powered (Mac) 1 11-12-2007 09:03 PM
Play/Edit Marker stopped following the timeline selection stern 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 2 05-22-2007 11:50 PM
