Moving M-Box 2 Sessions into ProTools 002 Rack to Record and Then Back to M-Box 2
I am using ProTools LE 7.4cs7, Mac OS 10.4.11 on a 2 x 2.66 GHz Dual-Core Intel Xeon.
I copied a ProTools LE M-Box 2 session over to my ProTools LE 002 Rack system to record some additional tracks for a client, and I was then going to save the additions and give the client a copy of the modified session with the additional tracks. After moving the M-Box 2 session I noticed that the record inputs names did not match those with my 002 Rack - I could not choose an input that was inherent with my 002 Rack. I could not figure out how to change the M-Box 2 inputs in the session to match 002 Rack inputs to record - and then change the inputs back to the M-Box 2 for the client. Does anyone know how to do this? This will be a regularly requested activity with this client. Please advise. Thank you. |
Re: Moving M-Box 2 Sessions into ProTools 002 Rack to Record and Then Back to M-Box 2
You use the I/O Setup window for this. You can always switch to the default I/O for the current interface pretty quickly by using the "default" button. Check out the manual/reference guide for more info.
Thanks for your initial reply. I did read the pages in the reference guide associated with I/O settings; and also spent some time in the I/O set-up window and had the following observations:
On the I/O setup window there are four tabs - Input, Output, Insert, Bus. At the bottom of the I/O window there are two buttons - Import and Export. I found that both the Import/Export functions work well but only for the current tab you are viewing - NOT for the group of settings (Input, Output, Insert, Bus). The problem with this approach is that you will need to save four separate Export settings files for say the M-Box 2 default settings so that you can Import them later to replace the 002 Rack default settings. Is there a way to save a complete I/O settings file for the M-Box 2 that includes all four settings - Input, Output, Insert, Bus? Again, I receive sessions from a client who creates the initial sessions with his M-Box 2, so I need to change the I/O settings to match my 002 Rack to record additional tracks (easy with the Default settings). Then, I need to be able to return the I/O settings to match his M-Box 2 before I return the session to him. Any idea how to do this as "one Exported settings file" rather creating four separate M-Box 2 I/O settings files? |
Need some help setting up ProTools to record with Eleven Rack | thrashmetl | Eleven Rack | 19 | 08-11-2013 11:11 AM |
Can't record from my Eleven rack into protools 10 | KirbyD | Eleven Rack | 1 | 03-01-2012 08:04 AM |
ProTools 8 M Powered won't play back after record | Leeber | Pro Tools M-Powered (Win) | 0 | 07-29-2011 04:53 PM |
Moving Protools 5.1 Mac sessions to Protools 6.4 P | unsub | Pro Tools TDM Systems (Mac) | 4 | 05-11-2004 10:34 AM |
Automatic Back Up of ProTools Sessions | KennyA | Pro Tools TDM Systems (Mac) | 7 | 11-12-2003 04:38 AM |
