Cinema Display and PT6 mix window???
When I first open a session the mix window is at full screen size 1200x1024. However if I resize it, the widow snaps to a default maximum of about 2/3 the resolution of my cinema diplay. 1200x768. It gets no larger.
Wierd....Does anybody else with a cinema display have this bug? |
Re: Cinema Display and PT6 mix window???
I have 2 22" cinema displays hooked up to the Titanium video card and I get the same problem in the mix window only. I'm using 10.2.4 and PT 6.01 but had the same problem in PT6.
Jamie |
I am also seeing this same behavior on my 22" Cinema with 10.2.4/6.0.1.
It's starting to drive me nuts not being able to have my mix window cover the whole screen. If we are ever able to resize this window again I would love to see a place to make some notes on the bottom of the mix window (below the comments) for the kind of stuff you'd normally notate on the back of a track sheet ie: outboard preamp/eq/compressor settings, comp notes etc. Also... when will we be able to resize the I/O Setup window?? I have multiple 192's and change my I/O setup often and this constant scrolling up/down & back/forth is also getting pretty old. |
Yes, resizeing the I/O window.
I Agree. I would love to see the whole layout with no scroll bar. |
The problem DOES exist on on all HD monitors. You can't resize the mix window to full screen (some of us use the open space for the Session Setup Window, Transpost and sometimes small video windows). Digi, could you look into this bug?
Bryan Jackson Independent Audio Systems Engineer Burbank,CA / Las Vegas, NV |
I would also like to be able to resize the "Gas Gauge" system usage window. I used to keep it tucked in the corner of the Cinema display in OS9, but the OSX version is HUGE and doesn't fit anywhere!
And where do you guys put the dock? Seems like it's always in the way. Jeff D. |
Shhhhh.
23" Cinema same problem [img]images/icons/frown.gif[/img]
20" or 23" cinema display? | rickenbacker12 | Post - Surround - Video | 2 | 10-20-2004 12:58 PM |
20" or 23" Cinema Display? | dfusion | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 7 | 03-02-2004 08:04 AM |
Cinema display and studio display | Nick Le Mon | Pro Tools TDM Systems (Mac) | 0 | 07-27-2002 08:41 AM |
Cinema Display + TV ?!?! | donpietra | Pro Tools TDM Systems (Mac) | 5 | 05-15-2001 05:12 AM |
22" cinema display | rndaudio | Pro Tools TDM Systems (Mac) | 4 | 12-07-2000 10:28 AM |
