Default Eq and Dynamics
It seems that the little bug i had that was fixed is back in 8.0.4
at random i will lose my Default EQ and Dynamics. i will open a new session and the defaults are gone. i'll reset them work for a bit, go to another session and there gone. this was fixed in some rev but seems to be back. anybody else seeing this. confirmed on 2 different machines running 8.0.4 did all the usual pref and data base trashing. thanks in advance zeeman l oS 10.6.3 PT 8.0.4 |
Re: Default Eq and Dynamics
Never had a problem here with default EQ and Dynamics SL 10.6.4 and PT 8.0.4 Chris
Thanks Chris,
Strange one. had this before and at some point a rev fixed it on my end. glad your not seeing it. i'll dig a little deeper. Thanks again zeeman |
Don't rediscover fire every time you start a new session.
Create a session with your basic set-up, a few tracks, inputs, busses, etc. Instantiate EQ/comp/Reverb - whatever, but de-activate them until you need them (or not - boots faster if they are "quiet"). Save it with your "favorite" EQ/dyn intact, and anything else you commonly use in a session. Save it again Go to that session file, get info. Check the box that says "stationery pad", then check "locked". Now, whenever you have a "new" session, open this session instead. It will ask you to 'save as", so save it as whatever it is you're doing. I have a preset for every different session - recording from ISDN, sending mixes, a 5.1 version, a stereo version, VO recording, rhythm date, etc. If you want to modify it, just unlock it & uncheck "stationery pad", open it, modify, save (close), and re-lock it/pad it again. |
thanks,
but i guess i wasn't clear. i'm talking about opening existing sessions. in my job i'm working on many different sessions a day. i will go back to a session that i worked on earlier or even the day before and the defaults are gone. I do use a temp for any new sessions with all of my plugs/screens already setup. great way to start a new session and we all start from the same temp. thanks again for your help zeeman |
no problem with dynamics in pt 8 problem with rane series dynamics at pt 8 | vageli | Pro Tools TDM Systems (Win) | 0 | 01-25-2011 10:00 AM |
Can Dynamics 2 and EQ 2 coexist with Dynamics 3 and EQ 3? | noharmlessrock | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 2 | 05-29-2008 11:23 AM |
Expander Gate/Dynamics III vs Drawmer Dynamics | DaveSB | Pro Tools TDM Systems (Mac) | 14 | 01-31-2007 05:26 AM |
7.2-User-definable default EQ & Dynamics question | PMoshay | Pro Tools TDM Systems (Mac) | 4 | 08-03-2006 11:50 AM |
Dynamics ? | jeam25 | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 2 | 03-31-2004 11:42 AM |
