Old 04-05-2009, 02:19 PM
pippington pippington is offline
Question PT le 8, I can only get signal while in record mode.
I have a macbook pro 2.5, Mbox 2 and PT le 8. I just started with it today. I can only see signal to the channel while record enabled (from my Mbox 2). I had Pre tools 5 and an AM 3 card years ago. I could play along with recorded material back then and monitor the sound without being in record enabled mode. I would like to create a track then mess with the sound before I record. I must be doing something wrong. How do I listen to my source without being in record enabled mode?
Old 04-05-2009, 02:47 PM
wwittman wwittman is offline
Default Re: PT le 8, I can only get signal while in record mode.
you need to put the track in Record READY, and then select INPUT ONLY MONITORING.
switch back to Auto Input Monitoring after you record, or you won't be able to hear the playback.
William Wittman
Producer/Engineer
(Cyndi Lauper, Joan Osborne, The Fixx, The Outfield, Hooters...Kinky Boots!)
Old 04-05-2009, 02:55 PM
Thank you for your quick answer. What I would like to be able to do is play along with previously recorded tracks without recording what I am playing so I can try out different things before committing them to the drive. If I am in record ready and then hit play won't I be recording?
Old 04-05-2009, 03:33 PM
Keybeeetsss's Avatar
Keybeeetsss Keybeeetsss is offline
Hi Pimpin...No; u won't be recording until u hit record... but as walt wittman said(sorry Will, I always just give ppl names)
just put it in input monitoring mode, arm the track & PLAY it, not record it...
Another thing u can do is create an aux track & set the input to whatever input u would be using on ur audio track & that would actually make u able to hear everything without the worries of Playing the track & recording
MYSPACE ON'EIM
LAUTEN MICS & ME
DA'TUBE ON'EIM
'IS TAMARA HOME'
NO, SHE'S WITH
HOBO KEY
'' (that dopey green thing)
('we' must start using pronouns)
Old 04-05-2009, 04:16 PM
Smile Re: PT le 8, I can only get signal while in record mode.
Thanks wwittman and Keybeeetsss I see what you mean. It worked.
Old 04-05-2009, 04:50 PM
Koolz...
MYSPACE ON'EIM
LAUTEN MICS & ME
DA'TUBE ON'EIM
'IS TAMARA HOME'
NO, SHE'S WITH
HOBO KEY
Old 04-05-2009, 06:05 PM
It worked.
Yes.
It always does.
Old 04-06-2009, 09:14 AM
Originally Posted by wwittman View Post
Yes.
It always does.
MYSPACE ON'EIM
LAUTEN MICS & ME
DA'TUBE ON'EIM
'IS TAMARA HOME'
NO, SHE'S WITH
HOBO KEY
No signal can't record theorganist macOS 1 12-02-2012 03:02 AM
Crackling in record mode (even when not actually recording), cannot record > 10 secs chandra 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 9 08-16-2010 09:08 PM
Midi Signal In - Will not record jhermais 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 1 01-09-2007 08:40 AM
input & output signal when arm to record mode rahman 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 0 12-30-2005 07:39 AM
Not getting signal to record wagonburner 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 3 07-20-2004 01:26 PM
