#31
Re: Mic Inputs Very Low (AGAIN WTF!!!) w/ Mbox 3
Still , having the same issue , after replacing mbox 3 with another new one. have to turn up gain all the way to where you can actually here noise to get adequate input level .. Using: Shure 57./w xlr both ends, 110 watt Fender tube amp. NO Pad. and pahntom power. THinking about trying a different mic for recording guitar....
#32
How loud are you running the guitar amp and is the SM57 right at the speaker (within inches?). You do not need phantom power on an SM57 or any other dynamic mic. Are you sure the mic and cable is OK? Do you have spares to check it with? Check for intermittent or corroded connections etc. Try flexing the cable shaking the mic etc. |
#33
Re: Mbox mini 3
Correct, you don't need phantom power for an SM57. That said, it shouldn't make any difference if phantom is on or off unless your mic cable is wired incorrectly. Which could also cause other problems. How loud are you running the guitar amp? You may simply need to turn the amp up. And this may sound silly, are you sure you have the mic over the actual driver and not just the part of the grill cloth over solid wood? It happens...
#34
hi inputs 1-2 and 3-4;5-6;7-8 .Win you connect to one of the two it sets the other one,so if you put a instrument in 1 or 2 you should put mic in 3 or 4 and yes the input will be low but not that low put eq;comp;or trim tool on it to bring up input
i use a pre before going in to M-box but thats me ! POPAJOE |
#35
Re: Mbox mini 3
#36
#37
If you can't get a loud enough signal using a SM57 with a 110 watt tube amp set to 4, how can you record vocals or acoustic guitar? Have you tried other inputs on the Mbox?
"Whiskey Bottle...Brand New Car...Oak Tree You're in my Way" RVZ Digi 002 rack , Command 8, Behringer ADA 8000, Tascam M-320B Mixer, Alesis Monitor Two Speakers, Vintage and Modern Tube Amps, Fender American Strat, 1973 Gibson SB-450 Bass, Epiphone Les Paul Traditional Pro, Roland W-30 Keyboard, Preimier XPK Fusion Drum Kit. |
#38
... And you're positive there's nothing wrong with the microphone. You've tested it elsewhere?
Pro Tools HD 12.4, Pro Tools "Vanilla" 12.4, Artist Transport, 2x Artist Mix Studio Blue: RME UCX, Win7 Pro, i7 960, 16GB || Studio Green: RME Babyface, Win10, i7 7700HQ, 16GB |
#39
For anyone still having these issues of low input levels on the Mbox 3, I'll share what I found and how I've been working around it.
I get this problem when using my 2 CAD m179 condensers. Apparently these are pretty power hungry condensers and it seems the phantom power on the mbox is not quite beefy enough to keep them both satisfied. I first found this out when I realized that I had normal levels with 1 mic but using them in stereo had very low input. Additionally, if I unplugged one of them, you can hear a pumping of the remaining mic as it starts to get fed enough juice. After it stabilizes, the level is at a much higher, usable level. If you plug the other one back in, it remains at the lower level and overtime, the loud mic's level will dwindle back down. Therefore, my workaround (though not fun) is basically, every 10-15 minutes or so, unplug one mic, let the other pump back up, then plug it back in and do the same with the other mic. At the end of this, you will have both mics with usable levels without the high noise floor. My theory is this pumping is charging the capacitors in the condenser mics which then runs down over time. Another problem I have with this workaround is sometimes plugging the mic back in will cause pro tools to lose contact with the mbox. The workaround I use for this: follow the steps above but before plugging the cable back in, select "Front" on the channel. After it's plugged in, you can reselect the "rear" mode. Hope this helps someone |
#40
If phantom power is misbehaving a simple fix is an outboard phantom power box... http://www.sweetwater.com/c959--Phantom_Power
More inputs than Mbox 2 | jordan_ellipsis | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 2 | 01-29-2007 02:40 PM |
How many inputs with Mbox 2 pro | Brad Summerfield | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 7 | 12-06-2006 08:26 AM |
TRS inputs on MBox | Marker | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 3 | 10-26-2004 10:35 AM |
Using the TRS inputs on the Mbox | djrocksteady | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 7 | 07-16-2004 03:33 PM |
Inputs on MBox | BlackOctopus | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 5 | 02-09-2003 02:05 PM |
