My System Build
Specs:
E8400 3.0ghz Core 2 Duo OCZ Platinum 4GB (2 x 2GB) 240-Pin DDR2 SDRAM DDR2 1066 (PC2 8500) 2 - Western Digital Caviar Black WD5001AALS 500GB 7200 RPM 32MB Cache SATA 3.0Gb/s Hard Drive ASUS V-60 92mm Vapo Bearing CPU Cooler EVGA 512-P3-N975-AR GeForce 9800 GT 512MB 256-bit GDDR3 PCI Express 2.0 x16 HDCP Ready SLI Supported Video Card ASRock X38TurboTwins LGA 775 Intel X38 ATX Intel Motherboard I WILL BE RUNNING PRO TOOLS 7.4 I WANT YOUR OPINION ON HOW EFFECTIVE DO YOU THINK THIS SETUP WILL BE WITH PRO TOOLS? THIS IS MY FIRST CUSTOM BUILD AND IM BUYING SOME MORE PARTS FOR CHRISTMAS. |
Re: My System Build
I have the same processor and my computer fly's and is extremely stable.
I know other there's a lot of other things that go into it, but that's just a nice CPU. Here are my specs running great with that processor. E8400 3ghz core 2 duo ASUS P5N-D mobo ZALMAN heatsink/fan Corsair Ram 2 x 2GB, the faster one that's .4 MS or nano seconds or whatever the measurement is. EVGA Geforce 8800 GTS (superclocked) Western Digital 250gig 16mb cache sata system drive partitioned into 2. 1 for Vista Home Premium, the second for XP Pro SP2 WD 500gig drive for recording sata WD 2 - 1 TB sata drives in Raid 1 configuration running off the Mobo's raid controller.
www.klarityrecordingstudios.com |
Re: My System Build
Thanks for the opinion.
Re: My System Build
I don't recommend you the Asrock board. Here everybody uses ASUS boards with great results. Check the Core 2 thread for more info.
Re: My System Build
I was going to get the ASUS board but the next one I saw with ddr3 capability was about 250 and more. The ASRock board has ddr2 and 3 capability for a nice price.
Re: My System Build
seamus |
Re: My System Build
Well im not buying the board right now so I will wait and see if the prices go down or asus comes out with another board for a lower price.
Re: My System Build
What good is DDR3 on this chip set and/or CPU? (none ) It would be like using unleaded fuel on an old car that doesn't need it... If you where going for Core i7 then you NEED DDR3. Also I would consider a quad core CPU, as PT knows how to take advantage of the extra cores, so you'll get almost double performance per clock. Q8200/Q6600 are low price alternatives. Q9550 would be the sweet spot. The Asus cpu coller wouldn't be my first choice to say the least. If you wanna go chep go AC freezer 7, if you want the best go with Termalright (Ultima 90, Ultra Extreme 120, or HR1+)
i7 2600K @ 4.4GHZ -- Intel DP67BG B3 -- 8GB DDR3 1600 -- Crucial SSD PTLE 8.0.4cs2 -- DIGI 003R -- DV toolkit -- Waves 9 |
Re: My System Build
With my rig I am doing Pro Tools mostly, but also video editing and I the E8400 will do for me. Seems like there are a lot of people recording with less. |
Re: My System Build
My normal sessions are around 22-28tracks with a bunch of plugs on all the tracks at at least 3 reverbs, and in PT8 in Vista (haven't tried my XP partition yet) I am getting 28-31% CPU Usage, So I have a good amount of headroom.
That's also at 512buffer, 2CPU at 85% settings
Need help with New System Build | Fireball71 | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 11 | 04-04-2009 09:26 AM |
New PC System Build! | dowtish01 | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 2 | 11-13-2008 08:08 AM |
How to build a miX System? | Leyenda Productions | Pro Tools TDM Systems (Win) | 4 | 08-13-2005 01:46 AM |
It can be fun to build your own system. | filmixer | Pro Tools TDM Systems (Win) | 0 | 07-30-2005 06:52 PM |
What do you think of this system I might build | ikon1234 | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 15 | 04-18-2004 06:43 AM |
