Old 04-29-2016, 03:02 AM
risey's Avatar
risey risey is offline
Default Will avid ever update their MBOX 3 drivers for win10?
I was running mbox 3 fine with Pro Tools 12.5, I originally upgraded from Windows 8 to 10 and had no problems. I bought a new case for the pc but cut the story short I decided to clean install Windows 10, now MBOX 3 wont work, the sound cuts out or I get a BSOD, also when I pull up the mbox control panel the sliders are jumpy when I try to move them, its like the whole thing is not compatible.
I looked at the audio panel and mbox is recognised by the PC. I loaded up PT 12 and it tells me it cant find an audio device.
I un installed drivers, re installed, removed firewire PCIE and replaced with another, no luck.
Anyone else having same issue?
Cheers
Ryan
http://www.PhatMonkey.me
Windows 10 64bit | Asus Rog Maximus X Formula Z370 | Intel i7-8700K CPU @3.70GHz, 3696 Mhz 6 Core(s) 12 Logical Processor(s) | Corsair LPX Vengeance 64g DDR4 RAM | Avid Mbox Pro 3 | Focusrite 18i20 2nd Gen | MSI GTX 1080TI Gaming X Trio | Acer Z35 Predator Monitor
Old 04-29-2016, 05:21 AM
sw rec sw rec is offline
Default Re: Will avid ever update their MBOX 3 drivers for win10?
You're absolutely right....it isn't compatible. Avid's official stand is "Don't try this on Windows 10." Although I do see many instances of it working, it's strongly recommended against.
Old 04-29-2016, 07:32 AM
risey's Avatar
Yeah I guess files carried over from 8 to 10 that is why I did not have any problems, I know it is trivial but I noticed windows photo viewer had vanished also which I still had in 10 after upgrading, so that alone tells me certain features have been removed, changed in WIN 10.
Avid are slow to update their drivers, I mean MAC had an update in January, last update for Windows was last summer... lol
I may have to invest in another audio device, thunderbolt one or something...
Old 04-29-2016, 09:30 AM
stanonbass stanonbass is offline
Windows 10 isn't even qualified for protools period. Lol
Meanwhile ALL other daws are that have Windows variants.
Old 04-29-2016, 11:23 AM
JoelG's Avatar
JoelG JoelG is offline
The Mbox 3 line aren't mentioned as devices that will not get Win 10 drivers, but I don't have any ETA on when they will: http://avid.force.com/pkb/articles/e...cts&popup=true
Joel
Jame Space:
HP Elite 6300 / Core i5 3570 / 12GB RAM / Win 10 Pro
Pro Tools 12 HD / Focusrite 18i20 + M-Audio ProFire 2626
Home:
Intel S5000PSL / 2 x Xeon E5450 / 32GB RAM / Win 10 Pro
Pro Tools 12 HD / M-Audio Project Mix IO
Rig:
Eleven Rack / ART SLA1 / Fender Mustang V 412 / FCB1010 w/ EurekaPROM
Old 04-29-2016, 12:20 PM
risey's Avatar
Hope it does get a driver, it has been an awesome audio device for over 4ish years for me.... :)
Ryan
Old 01-17-2017, 04:33 AM
risey's Avatar
The fix is under this post, in short the X99 motherboards have an IRQ problem but there is a workaround http://duc.avid.com/showthread.php?t=388018
will Avid update the 11 rack drivers to work with 12 ddropski Eleven Rack 12 11-15-2016 06:07 AM
Avid How Can I Be Having Problems With Your Mbox Drivers Again! shamanrock Pro Tools 11 0 05-10-2014 10:53 PM
9.0.2 and updated 003 drivers, but no mbox 2 pro driver update? remis Windows 8 03-24-2011 07:00 AM
Mbox drivers are messing with my PC. How do I remove or update them? uz3r 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 1 08-07-2010 08:43 AM
