Issue with C400
I have a strange issue with my M-Audio Fast Track C400
After having my PC running for a while, it just sort of stops working, windows realizes it's there, but audio from itunes wont play, and i get the -6006 error when trying to start Pro Tools SE. If i can get any help it would be aprreciated EDIT: also i get it to work again by unplugging it and plugging it back in |
Re: Issue with Fast Track C400
That's a common issue with c400 cards.
It's audio driver causes system to hang or crashe when your system goes to power saving mode. M-audio support claims it's normal(hangs and even BSOD on some systems) and recommends turning off powersaving. That's how they fix it. People thinking about buying this card should also know that it does not support recording `what you hear` in Windows 7. It also does not support using Microsoft Sound Mapper for recording via SP-DIF. If you are planning to work with multiple apps using SP-DIF for recording, you should avoid this card. I've used this device for 3 months and due to instability, I had to switch back to my old M-audio card, which is solid unlike c400. When multiple audio apps are running (with C400 audio driver selected as audio device) system becomes extremely "laggy". You see the hourglass mouse icon when you switch between audio apps and you have to wait for audio drivers to become active before hitting play button, as if they are getting re-initialized every time you switch apps. (none of these happen on my old MAudio card) It works "fine" with Microsoft Sound Mapper if you are not using the SPDIF in. Buy with caution. |
Re: Issue with C400
Are you using the latest drivers available for the C400?
Can you post your full system specs and have you gone through all the Optimization's? The C400 is now supported by Avid not M-Audio, although as mentioned I still don't think the driver supports power saving. Joel
Jam Space: HP Elite 6300 / Core i5 3770 / 24GB RAM / Win 11 Pro Pro Tools HD / Focusrite 18i20 + M-Audio ProFire 2626 Home: Asus B450 Pro4 / Ryzen 5 2600 / 32GB RAM / Win 11 Pro Pro Tools HD / Focusrite 18i20 + M-Audio ProFire 2626 Rig: Eleven Rack / ART SLA1 / Two 2x10 Passive Monitors / FCB1010 w/ EurekaPROM |
Re: Issue with C400
My system specs are
Motherboard: GA-970A-D3 Proccesor: AMD Fc-4100 Quad core @ 3.6Ghz Memory: 12GB Display: AMD Radeon HD 7800 Version9.12.0.0 (having issues with that too, im like a magnet for computer issues) Sound:M-Audio C400 Version 5.10.000.6016 and I'm installing the newest driver, but I'm pretty sure i already have it |
Re: Issue with C400
Thanks |
FT C400 driver issue | donjepski | FireWire & USB Audio Interfaces (Win) | 3 | 03-05-2014 09:35 AM |
ProTools SE and C400 fastrack | Myleftoe_C400 | Pro Tools SE and Essential (Win) | 11 | 04-08-2013 01:59 AM |
C400 headphone control | TheBoss2012 | Pro Tools SE and Essential (Mac) | 0 | 11-21-2012 03:06 PM |
Frustrated with C400 / SE combo | Vanight | Pro Tools SE and Essential (Win) | 4 | 09-04-2012 07:04 AM |
PT SE 8.0.3 / XP Sp3 / C400 | djmerkone | Pro Tools SE and Essential (Win) | 2 | 10-19-2011 05:15 AM |
