Jerky quicktime!!! Still!!!
When will this problem be adressed finally? i'm tired of posting my sys-specs etc....
Video stuttering still randomly happens on 8.01-8.1 CS 2. with every codec etc... PLZ DIGI!!! FIX IT!!! beamsync off, CS updates, NOTHING EVER WORKED FOR ME. I'm longer willing to spend 10k for a HD System that isn't even able to give me the safeness of good video playback, this is blaming me in front of my clients regularly!!! Really, PLEASE ADRESS THIS! this really sucks!!! |
Re: Jerky quicktime!!! Still!!!
I'm a customer but I've done a lot of testing with QuickTime and Pro Tools, so I wanted to ask you a couple of questions, if that's ok - I apologize that I don't know where your other posts are, so...
I'm assuming you're on a G5 with OS X 10.5.8 I'm also assuming your QuickTime is on a second monitor off the display card and that they are both DVI. Let me know if this is not the case. 1) Are your monitors both set at the same resolution? If not, does setting them both at the same resolution help? 2) Assuming the QT is on the second monitor (with nothing from the first monitor overlapping onto the second), does making the QT window *slightly* smaller make a difference? Does the jitter go away with QT at 1/2 size on the second monitor? 3) If you completely hide the Pro Tools windows on the main monitor does the stuttering completely go away on the QuickTime monitor? 4) If you move your QuickTime picture to the main monitor (leaving the PT counters visible) does it still stutter? dc |
[/QUOTE] Quote:
Beamsync enable/disable didnt help, PT 8.0 to 8.1 jitter, CS update didnt help, normally about 3-4 restarts help, deleting prefs never helps, sometimes disabling eternet helps, changing resolution or codec never help, jitter goes down to 320xsomething also at every frame rate. thanks for your help. thomas |
Jerky Quicktime playback in PT9 | mostlypost | Post - Surround - Video | 58 | 01-03-2012 11:35 AM |
Quicktime jerky 8.0.3 | TVPostSound | Post - Surround - Video | 151 | 10-27-2010 05:52 PM |
PT mtc jerky ? | Aquarius | Pro Tools TDM Systems (Mac) | 0 | 07-30-2010 04:35 PM |
Jerky Quicktime playback | Studio Studio | Pro Tools TDM Systems (Mac) | 7 | 07-20-2010 08:26 AM |
7.1 Running Jerky | Papajelly | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 0 | 07-16-2006 11:00 AM |
