Old 06-07-2019, 09:58 AM
Ben Wood Ben Wood is offline
Default 'write automation to selection' keyboard shortcut
Is there a 'write automation to selection' keyboard shortcut?
I'm using auto preview to dial in the setting on a eq.
If I use 'Write to All Enabled' is overwrites volume automation when I inevitably forget to switch it off in the auto window.
I can use a controller but if there was a shortcut, that would be ace!
Thanks
Ben
Old 06-08-2019, 03:53 AM
Norad155 Norad155 is offline
Default Re: 'write automation to selection' keyboard shortcut
Unfortunately no.
I put the automation window in the bottom right corner (store it in a window config for easy recall if you close it by accident) and automate a mouse click for 'preview' 'write to selection' and 'auto match' with Keyboard Maestro. Works like a charm.
IMDB
Old 06-08-2019, 05:26 AM
Tim R. Tim R. is offline
The primary use of the iOS app for me is Preview/Write to selection and number pad shortcuts (when I'm on my laptop).
Tim Reisig
System 1: Pro Tools Ultimate 2019.4.0, HD Native TB, HD OMNI, S3/Artist Transport/Eucon, Rosetta 800 w/XHD card
Mac OS 10.14.1, 2018 Mac Mini 3Ghz i5, 32Gig RAM
System 2: Pro Tools 2018.4 (no Hardware), Mac OS 10.12.2, MBP (Retina 13in, Early 2015, 3.1Ghz i7, 16Gig RAM)
Old 06-09-2019, 08:51 AM
reichman's Avatar
reichman reichman is offline
It's hard not to be cynical about the lack of key commands for advanced automation. But that ain't going to change any time soon. For any Pro Tools user who actually understands what Preview does, you owe it to yourself to buy a PT|Dock at a minimum. You will work A LOT faster with it. And I you have the coin, there are plenty of ways to upgrade from that.
Nathaniel Reichman
Supervising Producer – Re-recording Mixer
Dubway Studios
Old 06-10-2019, 07:35 AM
AudioUproarBen AudioUproarBen is offline
Thank for all the replies
I've had a look at keyboard maestro and i've got 'auto preview' and 'write auto to selection' setup. Seems to work really well.
Thanks all
Old 06-10-2019, 08:15 AM
garnoil garnoil is offline
I have the artist control and I programmed all these key commands to custom made macros, it is incredibly effective, not only for these automation commands, but for a lot of other workflows.
Old 06-10-2019, 01:30 PM
Cheesehead Cheesehead is offline
Ipad and PT control... Boom!
A mini S6.
Mac Pro 6,1 12 core, OSX 10.12.5, HD-Native TB, Trinnov MC, 888 IO, 192 IO, Sync HD, AJA IO XT, MC Mix, PT Control, Eucon 19.5, PT 2019.5
Old 06-11-2019, 06:25 AM
seraph_np seraph_np is offline
Opt+Command+V ?
seraph_np
Old 06-19-2019, 12:42 AM
simonchase simonchase is offline
+1 For keyboard maestro. I set it up once and now I never have to think about it, it's just like a keyboard shortcut
PT Ultimate 2019.5 - Mbox 3 Pro ---- MacOS 10.12.6 - Mac Pro (Mid 2010) - 2 x 3.46 GHz 6-Core Intel Xeon - 48 GB 1333 MHz DDR3 RAM - SSD Startup Disk ---- AJA Kona LHi PCIe
HTML code is On
Write automation to selection Toto2004 macOS 0 10-11-2011 04:38 AM
Keyboard Shortcut for Track Controls like Write Mode? miked45 Post - Surround - Video 2 08-18-2011 12:55 PM
Automation - write to all shortcut Studio Studio Pro Tools TDM Systems (Mac) 2 03-05-2009 05:06 AM
Write a snapshot of Automation to a selection? sco Post - Surround - Video 25 08-11-2005 03:32 PM
Write automation keyboard shortcut Hervé GUYADER Tips & Tricks 0 07-02-2003 02:52 PM
