Old 08-28-2009, 02:56 AM
NGokhool NGokhool is offline
Unhappy Digi Core Audio Manager
Hi all my first time on here :)
Im having a problem with the digi core audio manager
I have Portools 8.0cs3 LE which i run from mbox2pro on a 2.2ghz 2gb 120gig mac book pro running leopard 10.5.8.
my problem is when I access the digicore audio manager in the protools directory I cant use it I press connect and nothing happens it wont find my hardware but protools seems to run fine most of the time
It does not allow me to either
Change the buffer size
enter the H/W setup
or adjust the level in digi core audio manager
short of reinstalling protools form scratch i have tried everything i can think off if any one can help me i would be most grateful
all the best
nathan gokhool
Old 08-28-2009, 04:35 AM
Ben Jenssen's Avatar
Default Re: Digi Core Audio Manager
You will find a lot of posts by people having various problems with DigiCoreAudioManager around here. But it seems difficult to pinpoint a reason for the instability.
Last time it acted up on me, it lost connection with its "clients" and would only serve one "client" at a time. I got the advise to use The Pro Tools Prefs Helper, and that did the trick for me.
I've used it before, but what I did this time was that I checked all nine options to remove prefs. This means, of course, that you will lose all Digi audio settings, and you must go thru hardware setup, buffer settings and so on.
Old 08-28-2009, 11:01 AM
DigiTechSupt's Avatar
I have Pro Tools 8.0cs3 LE which i run from mbox2pro on a 2.2ghz 2gb 120gig mac book pro running leopard 10.5.8.
The Mbox2 Pro does not use the Core Audio Manager, but instead has it's own control panel available in System Preferences. You can configure the Mbox2Pro Core Audio Driver using the Mbox2Pro Control Panel, or from within most third-party Core Audio compatible client applications.
Please see the Core Audio Drivers Guide.pdf for more detailed information.
Macintosh HD > Applications > Digidesign > Documentation > Pro Tools
Avid Audio Tech Support
Support FAQ
Digi core audio manager mafiacondon Pro Tools TDM Systems (Mac) 0 07-06-2010 06:39 AM
itunes 7.5 and digi core audio manager DjA 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 1 01-08-2008 08:25 AM
Digi Core Audio Manager Tombolino 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 0 04-01-2007 05:31 PM
Digi TS: Problem w/current Digi Core Audio Manager Armando Pro Tools TDM Systems (Mac) 4 10-11-2006 10:08 AM
Digi Core Audio Manager gjohung 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 5 01-09-2006 11:54 PM
