Old 03-02-2018, 08:09 PM
Nick Cancilla Nick Cancilla is offline
Default Pro Tools 2018 use with 192 I/O [solved]
Hello, I understand that HD I/O's are supported in Pro Tools 2018. But, although untested by Avid, will my 192 I/O hardware work with 2018? Has anyone tried this?
Best Regards,
Nick
Old 03-02-2018, 08:42 PM
Neale Eckstein's Avatar
Neale Eckstein Neale Eckstein is offline
Default Re: Pro Tools 2018 use with 192 I/O
Yes. Works fine. I have one of each
Old 03-03-2018, 02:29 AM
lae777 lae777 is offline
192 working fine for me with 2018.1 and High Sierra.
5,1 Mac Pro, 3.46 GHz Six Core Xeon, 48gb ram, Pro Tools Ultimate 2023.6, HD Native card, Avid 192io interface, Avid 96io, Intensity Pro video card, Radeon HD 7950 graphics card, Mac OS Monterey 12.6.7.
Old 03-03-2018, 08:09 AM
Dear Neale and Iae777,
Thanks a lot for answering so rapidly!
This is very helpful.
Best Regards,
Nick
Old 03-05-2018, 05:46 AM
noah330 noah330 is offline
Default Re: Pro Tools 2018 use with 192 I/O [solved]
192 here as well - runs fine with an Omni.
Apple M1 Mac Studio (base model)
ProTools Carbon w/SSL XLogic MADI-AX
Instagram:
https://www.instagram.com/sparkletune/
Old 12-19-2018, 04:30 PM
aaquilato's Avatar
aaquilato aaquilato is offline
lea777
Thinking about upgrading to PT12.
I run OSX 10.8.5 with a PCI based PT10HD4 system.
Since my "Hack" has a digital output I can also run PT11HD Native using my UA192 as the DA converter
Can you tell me if I can use an Omni interface to launch PT 12 and still use my older Blue 192 as i/o?
AQ.
AQ.
Mac OSX Mojave 10.14.6 running Pro Tools Ultimate 2023.6
Mac OSX Mojave 10.14.6 running Pro Tools Ultimate 2022.9
Black Lion modified OMNI HD w/XB clock
Multiple Black Lion modified 192 FM/XB interfaces
Mac OSX ML 10.8.4 running PT10.3.7 HD4 PCIx (TDM & Native)
Old 12-19-2018, 08:20 PM
Originally Posted by aaquilato View Post
lea777
AQ.
Blue 192's still work. Running 2018.10 Ultimate here(HDN card) and a pair of HD IO's and a pair of 192 IO's zero issues
Old 12-19-2018, 09:15 PM
I concur.
My 192 is working flawlessly with 2018.12 and OS 10.13.6.
Old 12-20-2018, 11:17 AM
Sugarnutz Sugarnutz is offline
This an issue I’ve been asking about and glad to hear! Thanx!
Gigabyte z390 Designare
I9 990K 4.7 GHz
64 Gb of DDR4 3200
Gigabyte RX580 8 Gb
Win 10 Pro
15" Mid-2015 MBP 2.2 GHz i7 16 Gb RAM
512 Gb Flash Drive - OS X 10.14.6
Old 12-20-2018, 01:07 PM
aaquilato's Avatar
OK.
Can I run PT12 with my Mountain Lion OS 10.8.5?
I would install that on a separate HD as I do not think I can have all 3 versions (PT10, PT11, PT12) on one system HD.
Thoughts? Advice?
AQ.
Xpand!2 2018 & Air Instruments 2018 lgreen100 Pro Tools 2018 16 02-15-2018 05:01 PM
Solo Safe Not Working in PT 12 nor 2018.1 [solved] Aquic macOS 1 02-05-2018 04:53 AM
PT 2018.1 crashes on boot, 12.8.3 worked perfectly [SOLVED] aklru Windows 5 01-30-2018 02:26 PM
Anyone else missing trim plugin after 2018 upgrade? [solved] ratava911 Pro Tools 2018 4 01-30-2018 06:08 AM
