Old 06-14-2018, 12:48 PM
gostudionc gostudionc is offline
Default PT Playback Issue
Hello all!
I've had an ongoing issue with pro tools and I can't seem to find a good way to resolve it. It seems with no rhyme or reason this tends to happen, and I will open a project and when I click play, the counter will jump to (essentially) the end of the project, and will not play anything. I will start my cursor at, say bar 6, and as soon as I click play again it jumps as far as it will go and plays nothing. Is this a simple fix? Anyone else with this issue?
Thanks
File Type: jpg Screen Shot 2018-06-14 at 3.47.26 PM.jpg (72.9 KB, 0 views)
Old 06-28-2018, 02:43 PM
Question Re: PT Playback Issue
What happens if you press the N key on your keyboard, then place the cursor at bar 6 and press play?
Old 06-28-2018, 05:14 PM
DetroitT's Avatar
DetroitT DetroitT is offline
Default Re: PT Playback Issue
Link Track and Edit Selection enabled
pg 635
Old 12-14-2018, 11:55 AM
anklebiter anklebiter is offline
I am encountering this same issue - PT 2018.7.0, Win10 64-bit, Orion32.
I was working on a session, when it got stuck in play - stop button, spacebar would not stop audio. A few seconds later, PT crashed.
After restarting and loading the same session, every time I press play, the cursor jumps to the end of the session and no playback occurs.
Everything else is functioning normally - session loads without issues, I can edit, etc., but this session will no longer play back. Audio plays as expected using the scrubber, but using transport is no go - upon pressing play, cursor always jumps to end of session and no playback occurs.
I've loaded other sessions, they play fine.
Playback Engine Issue (Won’t load session with chosen playback engine) MattyJones Pro Tools 11 0 11-02-2015 11:52 AM
MP9 Playback issue Audity34 Pro Tools M-Powered (Mac) 5 03-15-2015 10:16 PM
Playback Issue - MP9 Dulip Gnanakan Pro Tools M-Powered (Mac) 5 03-27-2012 10:39 PM
PlayBack Issue... TheDot 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 1 10-07-2010 08:18 PM
6.7 amd DVD playback issue? Armando Pro Tools TDM Systems (Mac) 1 11-05-2004 02:02 PM
